ᐅ Ground floor approximately 100 sqm, upper floor adaptable for expansion (planned bathroom, 2 children's bedrooms, 1 storage room)
Created on: 28 Mar 2018 10:32
pffreestyler
Plot size: 879 sqm (9,458 sq ft)
Slope: no
Site occupancy index: 0.3
Floor area ratio: 0.45
Building envelope, building line and boundary: 5 m (16 ft) to the street, 3 m (10 ft) each to the orchard area and neighbors
Edge development /
Number of floors: 2
Roof type: gable roof
Construction style: solid / masonry
Maximum heights / limits: ridge height 9.0 m (30 ft), eaves height 6.0 m (20 ft)
Other requirements
Homeowners’ requirements: living room facing south, small office (initially used as a nursery), walk-in shower on ground floor, utility room on the driveway side
Basement, floors: no basement, 1.5 stories
Number of residents, age: 2 – under 30
Office use: family use rather than home office
Number of overnight guests per year: 2-3
Open or closed architecture: closed
Traditional or modern style: rather traditional
Open kitchen, kitchen island: no
Number of dining seats: 6
Fireplace: no
Music / stereo wall: no
Garage, carport: carport planned later on the east side
Designer: general contractor
What do you like most? Why? living room facing south, the number of rooms as desired
What do you dislike? Why? the office window 1 should be moved from south to west (otherwise the wall looks too bare); driveway and access to be on the east, not the west
Price estimate by architect/planner: available after Easter; currently mainly focused on the floor plan
Personal price limit including fixtures: expected around €1,700 per sqm (sq ft conversion not added per instruction)
Preferred heating: gas
If you have to give up, which details/features?
-can give up: bathtub
-cannot give up:
The floor plan is based on a very similar layout seen during a house viewing and is our favorite among all viewings and catalog research. We only adapted it slightly to our needs (removed guest WC and enlarged living room, rotated office).
The floor plan basically fits us, but I would appreciate your opinion to see if any improvements are possible. Note: as mentioned, we want to move the office window to the west so the wall doesn’t look so bare. Driveway on the east, not west. Therefore, the bare wall on the west is where the carport will go up to the utility room door. Alternatively, a window could be added to the living room there and the carport start behind the house. The plot allows this.
My main concern is that we’re not 100% happy with the roof’s east-west orientation; I would prefer a north-south alignment. Do you have ideas on rotating the floor plan 90 degrees while keeping the layout mostly unchanged? Only the kitchen and office could be swapped.
PS: The square meter figures for the hallway may be incorrect; the contractor will finalize after Easter. Correct figures will be approximately: living room 31.79 sqm (342 sq ft), kitchen 15.19 sqm (163 sq ft), utility room 9.87 sqm (106 sq ft), hallway about 19.5 sqm (210 sq ft), office/child room 1 about 8 sqm (86 sq ft), bedroom about 11.8 sqm (127 sq ft), bathroom about 8.5 sqm (91 sq ft)
Plot details: length west: 40 m (131 ft), east: 42 m (138 ft), width: 21.5 m (71 ft)
Spunk
29 Mar 2018 18:27
pffreestyler schrieb:
Is there a program where I/we can draw with exact specifications of room sizes, etc.?
My house planner
Sweet Home 3D
Revit 2018
Roomsketcher
Although all are more or less basic.
haydee
29 Mar 2018 19:09
The utility rooms tend to get quite warm. It might be worth considering a separation.
Possibly omit the exterior door to gain more usable space.
It is good that you only consider designs without steps as age-appropriate.
11ant29 Mar 2018 20:02
Nordlys schrieb:
If you want to think completely differently, try this. You could omit one room and make another one bigger instead.
Recreating your floor plan would mean needing slightly more floor space and postponing finishing the attic until the child is older—which, in my opinion, is definitely worth considering. My tendency would be the opposite: place the office upstairs right away and reduce the overall footprint.
Maybe the original poster will browse through the thread of another young settlement house builder: https://www.hausbau-forum.de/threads/grundrissplanung-Einfamilienhaus-mit-rund-150-m.26772/
Nordlys schrieb:
While others, like me, find it very good.
You can’t be serious: a double bed storage room used as a substitute bedroom even loses a corner so you can reach the child’s back room—how is that a very good floor plan?
Nordlys
29 Mar 2018 20:53
What you’re criticizing—the too small, awkward bedroom—can actually be fixed if you think in a Danish way and access the so-called kids’ room from the living room, which eliminates the need for the hallway at the back. For a home office, which isn’t meant for receiving clients, that’s perfectly fine; for a children’s room with a real child, it could be too noisy. A baby might still manage, but after that... the room needs to be upstairs. That’s really the downside of living on one level: you’re close together and can hear everything. On the other hand, an apartment is similar in that regard.
Imitating my floor plan wouldn’t be an issue in terms of space; they have enough land. It would just delay converting the attic. But that wasn’t the reason I showed it. It’s an example of a usable staircase that doesn’t take up excessive space. A straight staircase really does require a lot of room and long, wide corridors. karsten
Arifas29 Mar 2018 21:05
I would definitely swap the kids' room and the bathroom. 8sqm (86 sq ft) cleverly arranged is enough for a bathroom with a bathtub. Then I would also swap the kitchen and the utility room, keeping their sizes the same.
I haven’t read the other posts yet. However, I find some of the rooms quite small for the floor space, while the hallway is very large.
29 Mar 2018 21:20
Come on! Crumple up the draft and toss it in the recycling bin – swapping parts won’t help. A new idea is needed.
Also, consider whether visitors or you want to enter the house over your dirty laundry or clean laundry. Alternative: leave out the main entrance door. The house is too small for two entrances and two dining tables. You don’t need endless floor space in the living room either.
