ᐅ Ground floor approximately 100 sqm, upper floor adaptable for expansion (planned bathroom, 2 children's bedrooms, 1 storage room)
Created on: 28 Mar 2018 10:32
pffreestyler
Plot size: 879 sqm (9,458 sq ft)
Slope: no
Site occupancy index: 0.3
Floor area ratio: 0.45
Building envelope, building line and boundary: 5 m (16 ft) to the street, 3 m (10 ft) each to the orchard area and neighbors
Edge development /
Number of floors: 2
Roof type: gable roof
Construction style: solid / masonry
Maximum heights / limits: ridge height 9.0 m (30 ft), eaves height 6.0 m (20 ft)
Other requirements
Homeowners’ requirements: living room facing south, small office (initially used as a nursery), walk-in shower on ground floor, utility room on the driveway side
Basement, floors: no basement, 1.5 stories
Number of residents, age: 2 – under 30
Office use: family use rather than home office
Number of overnight guests per year: 2-3
Open or closed architecture: closed
Traditional or modern style: rather traditional
Open kitchen, kitchen island: no
Number of dining seats: 6
Fireplace: no
Music / stereo wall: no
Garage, carport: carport planned later on the east side
Designer: general contractor
What do you like most? Why? living room facing south, the number of rooms as desired
What do you dislike? Why? the office window 1 should be moved from south to west (otherwise the wall looks too bare); driveway and access to be on the east, not the west
Price estimate by architect/planner: available after Easter; currently mainly focused on the floor plan
Personal price limit including fixtures: expected around €1,700 per sqm (sq ft conversion not added per instruction)
Preferred heating: gas
If you have to give up, which details/features?
-can give up: bathtub
-cannot give up:
The floor plan is based on a very similar layout seen during a house viewing and is our favorite among all viewings and catalog research. We only adapted it slightly to our needs (removed guest WC and enlarged living room, rotated office).
The floor plan basically fits us, but I would appreciate your opinion to see if any improvements are possible. Note: as mentioned, we want to move the office window to the west so the wall doesn’t look so bare. Driveway on the east, not west. Therefore, the bare wall on the west is where the carport will go up to the utility room door. Alternatively, a window could be added to the living room there and the carport start behind the house. The plot allows this.
My main concern is that we’re not 100% happy with the roof’s east-west orientation; I would prefer a north-south alignment. Do you have ideas on rotating the floor plan 90 degrees while keeping the layout mostly unchanged? Only the kitchen and office could be swapped.
PS: The square meter figures for the hallway may be incorrect; the contractor will finalize after Easter. Correct figures will be approximately: living room 31.79 sqm (342 sq ft), kitchen 15.19 sqm (163 sq ft), utility room 9.87 sqm (106 sq ft), hallway about 19.5 sqm (210 sq ft), office/child room 1 about 8 sqm (86 sq ft), bedroom about 11.8 sqm (127 sq ft), bathroom about 8.5 sqm (91 sq ft)
Plot details: length west: 40 m (131 ft), east: 42 m (138 ft), width: 21.5 m (71 ft)
Slope: no
Edge development /
Number of floors: 2
Other requirements
Fireplace: no
-cannot give up:
Nordlys schrieb:
And the utility room door split in the middle, then you can only open the top part and look out. I also like a stable door. But whether that, together with the children's room access from the living room, the missing corner, and turning the bed, is enough to fix the floor plan—I’m still not convinced.
Nordlys schrieb:
And the utility room door is split in the middle, so you can only open the top part and look out.... even Mr. Ed would be happy about that...
Nordlys schrieb:
Who is that? Rupp. TV series from the 1960s, a talking horse that often looked out from a door split in the middle. Doesn’t ring a bell?
About “Rupp.” Don’t you think I would have chosen my nickname differently if I wanted to be called that? So, if you don’t mind... [emoji6]
pffreestyler schrieb:
Please don’t consider me resistant to advice, but I’m afraid we won’t fully agree on this.
Reducing it to just one door is not an option for us. It actually seems to be a regional peculiarity (which I wasn’t aware of before), but we don’t want to miss having a door to the utility room.
However, we will take nordlys’s suggestion: the children’s room will only be accessible through the living room, and we will extend the living room wall all the way to the bedroom. This removes the awkward bend in the hallway and eliminates the bend in the bedroom as well. Additionally, we should rotate the bed 90 degrees to allow better access to the window.Unbelievable. Did this floor plan cost you $10,000 that you’re so fixated on a design where a third (1/3) of the 100 sqm (1,076 sq ft) area is hallway?
Now you’re reducing 33 sqm (355 sq ft) to 30 sqm (323 sq ft), and everything will be fine?
[emoji33]
