ᐅ Effectively Cleaning IKEA Metod Countertops Without Scratches
Created on: 28 Mar 2022 07:32
Togusan
Some time ago, I installed the countertops from the IKEA Metod kitchen and now want to clean their surface in the long term as effectively and, above all, scratch-free as possible. According to the manufacturer, the surface is melamine-coated, which means it has a smooth and durable finish.
My question to the community: Which cleaning agents and methods would you recommend for thoroughly removing everyday dirt (grease, water stains, light crumbs) without scratching or damaging the surface seal? Are there any specific no-nos or home remedies that should be avoided? And if so, why?
I would appreciate any technical details or experiences with special cleaners or care products.
Thanks in advance to everyone for the quick responses.
Perhaps I can add that my countertop in the kitchen area often gets splashed with water (from the faucet or while chopping) – what is the best way to deal with stubborn water stains or deposits in this area?
Are special cleaning products for melamine surfaces useful or rather unnecessary? Is it worth investing in them?
And again regarding home remedies: I have heard about baking soda and baking powder for removing stains – are these effective or are they too abrasive?
cassandra28 Mar 2022 13:37For water stains on melamine, regular and thorough drying is actually the most effective solution. If deposits form, you can try using a damp microfiber cloth with a little dish soap.
Baking soda powder is slightly abrasive but may be helpful for particularly stubborn stains if used carefully – for example, as a paste mixed with water, gently rubbed in, then wiped off thoroughly.
However, you should always test first in an inconspicuous area to avoid any damage.
cassandra schrieb:
Baking soda is mildly abrasive but can be useful for particularly stubborn stains if used carefully.That’s a good point. However, when using baking soda, I specifically recommend only soft cloths and limiting the application time, as frequent or intense use can dull the surface.
Regarding maintenance products: Melamine countertops generally do not require special care. Regular cleaning and drying is sufficient. Specialized maintenance oils are unnecessary and can even leave residues.
Togusan schrieb:
Are special care products necessary for melamine, or are they rather unnecessary?I would say unnecessary. Melamine-coated boards are designed to require very little maintenance. Simply clean and dry thoroughly – usually, that’s all you need.
Togusan schrieb:
I heard about using baking soda and baking powder to remove stainsBaking powder has a similar effect to baking soda, but you should use both with caution. It’s better to apply them as a paste and avoid scrubbing aggressively.
FAVALERIE929 Mar 2022 08:24To avoid scratches: do not use scouring pads, steel wool, or stiff brushes. For everyday cleaning, warm water and thorough drying are sufficient.
