ᐅ How can I protect the surface of Ikea Brimnes furniture after purchase?
Created on: 6 Aug 2018 10:11
alican33
I own several pieces of furniture from the Ikea Brimnes series, which I really like. However, I often wonder how to best protect the surfaces of these pieces after purchase. The Brimnes furniture is known for its melamine-coated surfaces, which seem quite durable but tend to get small scratches and wear marks quickly with everyday use.
That’s why I’m asking here in the forum: How can I effectively protect the surface of Ikea Brimnes furniture afterwards without compromising the appearance or having to use complicated and time-consuming methods? Are there special sealants, varnishes, or other products that work well and are easy to apply?
I’m looking forward to hearing about your experiences and tips!
Issac_kla2 schrieb:
Brimnes is quite sturdy and affordable. I think the effort is hardly worth itThanks for this assessment; it gives me something to think about. Still, I want to avoid my furniture looking heavily worn after only a short time. My assumption is that with some kind of after-treatment, the lifespan can be significantly extended.
So, to clarify: Does anyone have experience with spray sealants, like those sometimes recommended for plastic furniture? Or could that be counterproductive because of the melamine coating? I’m also curious whether sanding beforehand is necessary to improve adhesion?
Looking forward to your opinions.
Good morning,
From a technical perspective, I like to look into these topics in more detail, as I often do some refinishing on furniture myself. Regarding the protection of the Brimnes surface, I can share the following:
- Melamine is very smooth and dense, so adhesion of paints or sealants is generally challenging. Pretreatment is almost always necessary, such as lightly sanding with very fine sandpaper (grit 320-400) to roughen the surface.
- It is important to carefully remove the dust afterward; otherwise, the paint will not adhere properly.
- It is best to use acrylic paint or a special plastic paint, which are usually water-based and provide very good adhesion.
- Spray sealants can work well, but only if the spray mist is applied very finely to avoid droplet formation.
- Build up several thin layers rather than one thick coat.
- Environmental conditions during application are crucial: too high humidity can dull the finish.
In conclusion: adhesion is problematic without sanding. It is also important that the furniture is not heavily used for 2-3 days after treatment, allowing the protective layer to cure.
Do you need recommendations for specific products or advice on which tools to use?
TEBILO schrieb:
A pretreatment is almost always necessary, for example lightly sanding with very fine sandpaper (grit 320-400) to roughen the surface.I completely agree. I once tried without doing it, and the paint didn’t stick at all — that was a failed attempt. So it’s better to take the time for light sanding.
TEBILO schrieb:
Apply several thin layersThat’s also my advice. Thick layers tend to look bad quickly and crack. Better to be patient!
V
vinicius448 Aug 2018 09:37Regarding the protection of Brimnes surfaces, I would like to add that there are special furniture care products available on the market designed specifically for melamine. These reduce the appearance of minor scratches by slightly filling the surface but do not provide mechanical protection like a varnish.
If you prefer a practical solution that does not require sanding, such furniture polish or care products can be an alternative. However, this is mainly a cosmetic protection rather than a harder protective layer.
For a genuine protective coating, the only option is likely the use of suitable varnishes or films, as already described.
alican33 schrieb:
Looking forward to your opinions.I just wanted to say that I’m familiar with this issue, and at first, the thought of extensive sanding put me off. In the end, I took a middle ground approach: I only sanded very carefully with fine-grit sandpaper in high-wear areas—for example, on the top edge of the cabinet—and then applied furniture wax. This gave me the protection I wanted without having to dive straight into major painting or finishing work.
Now it feels more like maintenance rather than something technical.
Maybe this practical approach will help you?
Layla schrieb:
Maybe this pragmatic approach can help you?Exactly, being pragmatic is often the best way, especially when it comes to everyday furniture like the Brimnes series.
Additionally, you could place very thin non-slip mats underneath (e.g., under drawers or dividers) to reduce wear from friction.
Summary:
- For maximum durability: light sanding + plastic lacquer
- For less effort: furniture wax + targeted maintenance
- For everyday use: careful handling and use of protective mats
I hope this clarifies the different options.
