ᐅ Ikea Besta – which care products offer the best protection for the surfaces?
Created on: 26 May 2021 08:37
layki
layki
26 May 2021 08:37
I recently bought an Ikea Besta sideboard and am now looking for the best care products to protect the surfaces over the long term. Since the Besta consists of a combination of coated wood and plastic elements, I especially want to know which products are recommended to prevent scratches, stains, and general wear without negatively affecting the appearance or feel.
I am particularly interested in specific recommendations for cleaners and care products that are suitable for the Besta surfaces—so not general-purpose cleaners. Are there products that have proven effective, or home remedies that actually work? It is also important to me that the products do not leave a sticky or greasy residue or any unpleasant aftereffects.
I would appreciate any experiences, advice on potential issues with certain products, and tips on the correct application!
sarla
26 May 2021 09:45
For maintaining Ikea Besta surfaces, I generally recommend cleaning with a microfiber cloth dampened with lukewarm water, followed by drying. For protection, a silicone-free furniture polish specifically formulated for coated surfaces is suitable.
I would avoid wax-based products, as they can leave residues and streaks, especially on plastic surfaces.
A proven product is, for example, "Dr. Schutz furniture care," as it creates a protective layer without altering the surface. It is also important to use cleaning agents free of alcohol and harsh solvents to avoid damaging the coating.
glamo
26 May 2021 11:22
I would like to add that when dealing with Besta surfaces, the exact material composition is important. Besta often uses melamine resin-coated particleboard or MDF with a foil coating.
Therefore, cleaning should never be done with harsh or abrasive agents, as this could damage the protective layer. Instead, I recommend a second step after cleaning: applying a care wax or sealant specifically designed for melamine-coated furniture.
These products form a thin protective film on the surface, reducing mechanical wear and staining. However, it is important to ensure that the wax is neither silicone-based nor applied too thickly to prevent stickiness.
Do you have specific surface types (matte, high gloss, foil)? This will influence my recommendation.
layki
26 May 2021 13:07
glamo schrieb:
Do you have specific surface finishes (matte, high gloss, laminate)? That influences my recommendation.
Thanks for asking! My Besta has a matte finish with a laminate coating. It will mainly be placed in the living area and used regularly, so I’m a bit concerned about the long-term effects of some cleaning products.
Tause
26 May 2021 14:16
A critical view would also be interesting: Many manufacturers label their care products as suitable for ‘all furniture surfaces,’ which is often simply exaggerated.
Especially foil laminates can be contaminated by oils and waxes, making them more vulnerable to dirt. If done incorrectly, there is a risk that dust will adhere more strongly or the surface will become dull.
The question here should be whether it might be more sensible to clean the surface regularly with a damp, soft cloth and deliberately avoid protective products in order to not unnecessarily stress the laminate.
Lorukeo
27 May 2021 07:02
Recommendations should be differentiated: For matte film coatings like those on Besta, it is often best not to apply additional protective layers, as these can alter the original finish.
A mild cleaning with distilled water and a lint-free cloth is usually sufficient. To protect against scratches, felt pads can be placed on the feet of objects that are moved across the surface.
Avoiding direct sunlight and heat sources also helps to extend the lifespan of the surface.
