ᐅ IKEA BESTA – How Can I Prevent Dust Buildup Inside?
Created on: 4 Dec 2023 08:47
Trevorfi33
I have several IKEA Besta cabinets at home that I use for media devices and books. What bothers me in everyday use is the quite significant dust buildup inside the cabinets—especially under the shelves and in hard-to-reach areas.
Since the Besta units usually have doors but are not completely airtight, I’m wondering: What effective methods are there to prevent dust accumulation inside IKEA Besta furniture? Are there any special tricks, materials, or approaches that can reduce the problem without having to constantly empty everything and clean manually?
I’m looking forward to your experience or technical tips on how to manage this issue long-term.
Laukau5
6 Dec 2023 11:17
Clear varnish sealing is indeed a proven method to minimize dust adhesion. For Besta backsplashes, glossy or satin finishes are recommended, as these surfaces are less porous than untreated or matte particle boards.
Important to note:
- Thoroughly degrease and sand before painting.
- Apply at least two thin coats.
- Dry after 24 hours, but full curing takes about 7 days.
The durability is long-lasting, with refreshing needed only after several years, provided the surfaces are not subjected to mechanical stress. For furniture areas, furniture lacquers or even clear oils with sealing effects are well suited.
When used indoors, ensure good ventilation.
Paunon
7 Dec 2023 08:37
To effectively prevent dust in the BESTA:
- Store devices in boxes or covers
- Improve seals on doors and back panels
- Smooth or seal interior surfaces
Additionally, using an air purifier in the room helps to generally reduce dust.
Trevorfi33
7 Dec 2023 10:21
Thank you very much for the many helpful suggestions! To summarize, I now have several approaches to reduce dust buildup INSIDE my IKEA BESTA furniture:
- Apply sealing strips to the back panels and doors
- Treat interior surfaces with antistatic spray or film
- Consider clearcoat sealing of the back panels
- Store contents in closed boxes whenever possible
- Clean regularly, but not too frequently
I may also invest in an air purifier for the room to lower the overall dust levels.
I will report back on what works best once I’ve implemented these measures. Thanks to everyone for the expert advice and practical tips!
