ᐅ How do I remove scratches from the surfaces of Ikea BESTA units?
Created on: 24 Mar 2023 14:07
GO-COLLING
GO-COLLIN24 Mar 2023 14:07Hello everyone, I have a problem with my Ikea Besta furniture and need your expert advice. There are scratches on the surface that are not deep but visible and affect the uniform appearance. The BESTA surface is melamine-coated, which probably makes repair more difficult. My specific question is: which methods and materials can be used effectively to remove or at least significantly reduce the appearance of such scratches without damaging the melamine coating? Are there any products, home remedies, or special techniques that have proven effective in practice? Thank you very much for your detailed tips!
Hello GO-COLLIN, to treat scratches on melamine-coated surfaces like those found on Ikea BESTA, I recommend the following structured approach:
- First, thoroughly clean the area to remove any dirt.
- For superficial scratches, a special furniture or melamine scratch remover available on the market can be used.
- Alternatively, gently polishing the surface in the affected areas with a fine polishing pad and a plastic or furniture polish often helps.
- It is important not to use sandpaper, as this could damage the melamine coating.
- For deeper scratches, repair with a suitable wax filler stick in the color of the surface may be an option.
These measures usually minimize the visibility of scratches effectively without damaging the surface. Careful handling is crucial.
In addition to pikin’s input: Melamine coatings are hard and scratch-resistant, which makes it difficult to completely remove scratches. However, light scratches can often be reduced by gently polishing with a microfiber cloth and a mild plastic care product.
Before using any products, I recommend testing them on inconspicuous areas. Deeper scratches can be repaired using color-matched repair kits, which are made of wax or lacquer. These fill in the scratches and visually conceal them.
Please avoid using aggressive solvents or abrasive cleaners, as they can damage the protective layer of the melamine surface.
I find it interesting that polishing and wax sticks are immediately recommended here. Honestly, most scratches on melamine are just cosmetic flaws that cannot be completely removed. It’s better to try to accept them or disguise them with decoration. Once polished or treated with wax, the surface can look uneven, which is often more noticeable than the scratches themselves.
So, just because something can be done doesn’t mean it always should be.
A structured guide for removing scratches on Ikea BESTA surfaces could look like this:
1. Cleaning: Thoroughly clean the lacquered or melamine surface with a damp cloth and some dish soap, then allow it to dry.
2. Assessment: Check the depth of the scratch – if your fingernail doesn’t catch, it is superficial.
3. Treatment of superficial scratches:
- Gently apply very fine abrasive fleece (e.g., 2000 grit) by sliding it over the surface.
- Afterwards, follow up with a plastic polish or furniture wax.
4. Treatment of deeper scratches:
- Use appropriate wax or paint repair kits designed for furniture.
- Apply thinly and evenly, then polish with a soft cloth.
5. Aftercare:
- Apply a protective layer using furniture care products or plastic sealant.
Important: Sandpaper is not recommended as it can damage the melamine layer. Patience and careful steps are essential.
5. Aftercare:
