ᐅ Which paints and finishes are suitable for painting IKEA Besta furniture?
Created on: 4 Feb 2020 09:37
Ra-raHello everyone,
I am planning to paint my IKEA Besta furniture myself and want to achieve a durable, well-covering, and naturally aesthetically pleasing surface. However, I know that IKEA materials are often melamine-coated or covered with laminate foil, which can make painting more challenging. My question is: which paints and coatings work best for painting IKEA Besta furniture, both in terms of adhesion and longevity?
I am especially interested in product recommendations (e.g., acrylic paint, 2-component paint) and preparation tips, as I want to properly sand and prime the surfaces. If anyone has experience with different finishes like satin matte or high gloss, I would appreciate your insights.
Looking forward to your tips and experiences!
For precise clarification: IKEA Besta furniture is often made of particleboard with a melamine resin coating or laminate. These surfaces are diffusion-tight and very smooth, so proper preparation is crucial.
- First, the surface should be sanded with 120-180 grit sandpaper to remove the smoothness and improve adhesion.
- After that, an appropriate primer suitable for smooth surfaces is necessary.
- For painting, a two-component polyurethane (PU) lacquer is recommended, as it offers high scratch and impact resistance. Alternatively, acrylic paint can be used, but it is less durable.
- There is a wide range of colors and gloss levels; semi-matte is usually the best choice for furniture, as it is less prone to showing fingerprints.
The combination of sanding, priming, and a durable two-component lacquer is the best method for refurbishing Besta furniture.
KLONA schrieb:
The combination of sanding, priming, and a durable 2K paint is the best method for refurbishing Besta furniture.Exactly! And if you prefer a high-gloss finish, it just takes a bit more patience when sanding and painting – but the result shines with a truly elegant look!
A small tip: Using a good fine-pored sanding sponge after priming will get the surface really smooth, almost like an expensive designer piece.
Good luck with the painting – you’ll nail it!
It is important when painting Besta furniture to thoroughly dust the surfaces beforehand; otherwise, sanding dust can become embedded in the paint. This becomes noticeably problematic later on.
Regarding the paint finish: some prefer a matte option because high gloss is more prone to scratches and fingerprints.
Personally, I like the combination of a matte primer followed by a satin or low-sheen finish.
