ᐅ How can I protect Ikea BESTA furniture for use in damp rooms?
Created on: 4 Apr 2019 08:43
arel1
arel1
4 Apr 2019 08:43
Hello everyone, I am considering using Ikea Besta furniture in a damp room, specifically in a part of our basement that occasionally gets a bit damp and has elevated humidity levels. My question is: How can I effectively protect the BESTA furniture from moisture to prevent warping, surface damage, or mold growth? Are there proven methods, special materials for surface treatment, or alternative installation options that might help? I look forward to your expert tips and experiences.
Ezekiel
4 Apr 2019 09:17
Regarding the question of how to protect Ikea BESTA furniture in humid rooms, I generally recommend avoiding direct contact between wood-based materials and moisture, as these are usually made of particleboard or MDF and are not moisture-resistant. Specifically, this means:
- Raise the furniture, for example on legs or panels, to prevent standing moisture from the floor affecting it
- Treat surfaces with waterproof sealants, such as a clear polyurethane-based furniture lacquer or special moisture-resistant coatings
- Additionally seal joints and edges with silicone or moisture-resistant sealing tape
- For especially humid rooms, consider applying a water-repellent foil or paint to internal walls and the back panels
- Use dehumidifiers and ventilate regularly to regulate the climate
The key is to prevent moisture from penetrating and to avoid using the furniture as a moisture reservoir.
farli
4 Apr 2019 09:52
Ezekiel schrieb:
Regarding the question of how to protect Ikea BESTA furniture for damp rooms, I generally recommend avoiding direct contact of wood-based materials with moisture, as these are usually made of particleboard or MDF and are not moisture-resistant.
That is certainly correct, but I would add that many users underestimate how low the moisture resistance of this furniture actually is. Unfortunately, Ikea does not provide specific moisture resistance values. Therefore, I consider it risky to use the furniture in areas with permanently high humidity, even with protective measures. The fundamental question here is whether it might be better to choose furniture with moisture-resistant core materials rather than trying to adapt standard BESTA solutions.
Dwight49
4 Apr 2019 11:04
As an addition: Those who want to use furniture in the basement or bathroom should consider alternative protective layers. For example:
- Applying water-repellent primers under the paint
- Treating edges with epoxy resin (highly resistant to moisture)
- Using acrylic or PU sealants at joints and interior surfaces
I also recommend checking all metal fittings for rust protection, as the damp environment can cause corrosion that may affect functionality.
arel1
4 Apr 2019 12:27
farli schrieb:
Therefore, I consider it risky to use furniture in areas with permanently high humidity, even with protective measures.
Thank you for the advice! The humidity in my basement usually ranges between 65-75%, so it's on the higher side. It’s not a wet room like a bathroom or laundry area with direct water splashing, but rather an overall elevated indoor moisture level. For this reason, I am indeed looking for practical protective measures and do not want to purchase furniture made of water-resistant materials, but rather the BESTA series, which I really like in terms of design.
Maybe this helps with the evaluation.
ladali
4 Apr 2019 14:11
With this more detailed information, it can be said that with a good primer and thorough sealing, the BESTA furniture can be well adapted.
The following approach has proven effective:
- Disassemble the furniture before installation
- Treat edges multiple times with a waterproof sealing varnish, especially at joints
- If necessary, apply a thin layer of moisture-repellent wood glaze on surfaces
- Additionally, laminate the back panels on the inside with a moisture-resistant foil
It is also advisable not to place the furniture directly against exterior walls where condensation may occur.
Regular inspections for damage and occasional resealing will provide long-term protection.
