ᐅ How can I cheaply repair a damaged surface on an Ikea Besta unit?
Created on: 21 Feb 2021 08:17
Taus37
Taus37
21 Feb 2021 08:17
I have owned an Ikea Besta piece of furniture for some time now, which I actually like a lot, but unfortunately the surface has worn or been damaged in some areas. Specifically, there are small scratches and spots where the paint or veneer has slightly peeled off. It is important to me that the repair stays as inexpensive as possible since it is just a cosmetic issue and I am not expecting a professional-level solution.
Has anyone had experience with how to best repair these kinds of surfaces on Ikea Besta furniture by yourself? What products or techniques would you recommend to discreetly and affordably fix the damage without having to buy expensive specialty items?
I look forward to any tips, instructions, or suggestions on materials that would allow me to carry out an acceptable and low-cost repair on my own.
nofomu
21 Feb 2021 08:39
Hello Taus37,
try using furniture repair wax or color-matched wax sticks. They are affordable, easy to apply, and do a good job of hiding scratches.
BEATE
21 Feb 2021 10:05
For minor paint damage, I would also use acrylic paint or wood repair markers. They are inexpensive and provide reasonably good durability.
lofar
21 Feb 2021 11:12
For the Ikea Besta surface, I recommend using a fine, neutral abrasive sponge to slightly roughen the edges, then touch up with a marker or wax. This way, you have minimal effort and very low costs.
eldubi
21 Feb 2021 12:48
An affordable solution is also applying matching-colored nail polish. This works surprisingly well, especially for small scratches, and is easy to do.
hauklo
21 Feb 2021 14:23
In summary: Ikea Besta units are usually made of melamine-coated particleboard or painted surfaces. Small scratches can be economically repaired using furniture wax. For chipped veneer, it is advisable to reattach the area with double-sided tape and a color-matched chalkboard film fabric if the surface is severely damaged.
Be careful when sanding: the surface is often thin and can be further damaged quickly. Therefore, it is better to perform targeted repairs using repair wax or touch-up pens.
If you want an even more affordable solution, neutral-colored repair markers from a hardware store are a practical option.
