ᐅ Ikea BESTA – How can I clean the surface effectively and without causing damage?
Created on: 10 Apr 2024 08:47
Nokijo
Nokijo
10 Apr 2024 08:47
Hello everyone, I recently got a Besta unit from Ikea and I’m using it as a TV stand. It’s important to me to clean the surface in a sustainable way without causing any shiny spots, dullness, scratches, or changes to the finish. As far as I can tell, the surface is some kind of melamine-coated particleboard or plastic laminate.
My specific questions are: Which cleaning agents and methods are suitable for regular use to remove dust, fingerprints, or light dirt? Are there recommended household remedies that are gentle on the surface but still clean effectively? And which substances or chemicals should I definitely avoid to prevent damage to the coating?
I’m looking forward to any experiences or tips, including a bit of background information about the surface or materials if possible. Thanks!
Leote
10 Apr 2024 09:35
Hello, for BESTA surfaces I recommend clear water and a soft cloth. Cleaning agents containing alcohol or abrasive cleaners should be avoided, as they damage the surface. If grease or fingerprints are an issue, use a mild dish soap foam and then dry thoroughly.
U
usbla
10 Apr 2024 10:12
The surface of the Ikea BESTA is usually made of melamine-coated particleboard or plastic laminate, which are relatively durable. For sustainable and gentle cleaning, I recommend:
- A finely woven microfiber cloth without a strong texture
- Lukewarm water with a few drops of neutral dish soap
- Gentle wiping, no vigorous scrubbing
Avoid cleaning agents containing solvents, abrasives, or alcohol, as they can damage the protective layer and cause visual changes. Sustainability can also be achieved through minimal use and proper care instead of aggressive cleaning.
Kinbu
10 Apr 2024 11:25
Hello Nokijo, I completely understand that you want to treat the surface of your BESTA furniture gently!
Melamine and plastic laminates are usually quite easy to maintain. It is important that you never use harsh cleaners or abrasive sponges, as they can leave the surface dull or rough. A soft cloth, slightly dampened, is sufficient for regular dirt. For tougher grease, I recommend diluted dish soap and water. Always follow up by wiping with a dry cloth to prevent moisture from seeping into edges or joints.
Home remedies like vinegar water are often not ideal because vinegar can damage the plastic.
Do you have any specific stains or dirt that are particularly stubborn?
Nokijo
11 Apr 2024 07:30
Thanks already for the tips, very helpful!
@Kinbu: Yes, that’s true, I was actually a bit uncertain about stains like lipstick or slightly sticky drink residues. I definitely don’t want to use aggressive methods, but for these kinds of stains, plain water sometimes isn’t enough.
Are there any sustainable ideas that won’t damage the surface? I want to avoid the surface becoming dull or even fading due to, for example, nail polish remover or strong alcohol-based cleaners.
Lorukeo
11 Apr 2024 08:44
Kinbu schrieb:
Home remedies like vinegar water are often not ideal because vinegar can damage plastic.
That is correct. Vinegar can cause fine cracks in the protective layer of plastic laminate and melamine.
For stains such as lipstick or sticky residues, I recommend:
- A few drops of mild dish soap in warm water, applied with a soft cloth
- Alternatively, 70% isopropyl alcohol on a cloth can be used, but very carefully and without vigorous rubbing
Important: Always test first in an inconspicuous area and never apply more aggressively than necessary. Afterwards, wipe thoroughly and allow to dry.
