ᐅ Which maintenance products are suitable for Ikea Hemnes wood surfaces?
Created on: 24 Sep 2020 18:07
tojoloHello everyone, I have some Ikea Hemnes furniture at home with typical wood surfaces, which are often made of solid pine or similar wood. I’m wondering which care products are best suited to clean and protect these wood surfaces without causing darkening or unsightly stains. Does anyone have specific knowledge about wood protection requirements for Hemnes furniture? I’m not looking for general advice but rather recommendations for products that have been proven to be gentle and effective on the typical lacquered or oiled Hemnes wood. I’m especially interested in whether you prefer specific wood oils, waxes, soaps, or cleaning wipes, and how often the treatment should ideally be applied to keep the wood looking good in the long term. Thanks in advance for your tips!
Hello tojolo! Your question is very clearly formulated – I really like that! 😊 I have several Hemnes furniture pieces myself and have had good experiences using mild wood soaps that gently clean the wood without damaging the surface. After cleaning, I usually wipe the furniture with a slightly damp cotton cloth to prevent moisture from soaking into the wood. Occasionally, I apply a special care oil for pine wood, which protects the surface and helps maintain the classic Hemnes finish. In my opinion, it shouldn’t be done too often because too much oil can make the wood sticky over time. From my experience, once a quarter is perfect. Has anyone else tried this method?
Thanks for starting this, tojolo – a very nice introduction! The Hemnes series has that beautiful, natural look that you definitely want to preserve. I’m also among those who, alongside gentle cleaning with wood soap or a special wood cleaner, like to apply a thin layer of furniture wax. This not only protects the wood but also enhances the appearance of light wear marks. I apply the wax very sparingly and use a soft cloth. Especially with pine wood—which is softer than many other types—I find wax protection very useful. It’s important, however, not to use harsh products, as these surfaces can quickly react sensitively.
Hi everyone, I can also contribute a bit to the topic of Ikea Hemnes wood. I was advised at a specialized store not to use strong cleaners or alcohol-based products, as they can damage the surface. I follow a combination of tips from here: regularly applying a special care oil that provides moisture, and cleaning occasionally with a mildly damp cloth. Taking care of edges and corners is especially important to me, as water or dirt tend to accumulate there quickly. Do you have any experience with which oils or waxes to use specifically? So far, I have mostly used regular furniture oils from the hardware store, but I’m not sure if that is the best option.
Hello tojolo, first of all, I appreciate your detailed question. This makes it easier to provide a targeted answer. For the care of Ikea Hemnes furniture, it is important to know that many of these pieces are treated with a clear lacquer or oil finish, usually matte. This means cleaning products should be as neutral as possible and free of alcohol and acids. Mild wood soap or special care products for pine wood that combine protection and cleaning are recommended. For protection, I suggest furniture oil based on linseed oil or furniture wax without silicones. The important thing is to first clean the surface, then, when the wood is dry, apply wax or oil sparingly. For Hemnes furniture, treatment every few months is usually sufficient, depending on usage. Do you use the furniture more in the living room or in the kitchen? Care differs in these areas due to moisture and contamination.
[@Tommy38, post: s6w4l1, member: XXX]Thank you, that really helps me. The furniture is mainly in the living room, so a relatively dry environment with hardly any significant moisture issues. Did I understand correctly that a mild cleaner is sufficient for regular use, and oil or wax treatments should be applied more sparingly and carefully? Which active ingredients in such oils are especially recommended? I’ve often seen linseed oil used, but are there other natural oils that are also well suited? Henry’s statement also made me curious:
