ᐅ Effectively Cleaning IKEA Metod Countertops Without Scratches
Created on: 28 Mar 2022 07:32
Togusan
Some time ago, I installed the countertops from the IKEA Metod kitchen and now want to clean their surface in the long term as effectively and, above all, scratch-free as possible. According to the manufacturer, the surface is melamine-coated, which means it has a smooth and durable finish.
My question to the community: Which cleaning agents and methods would you recommend for thoroughly removing everyday dirt (grease, water stains, light crumbs) without scratching or damaging the surface seal? Are there any specific no-nos or home remedies that should be avoided? And if so, why?
I would appreciate any technical details or experiences with special cleaners or care products.
Togusan
29 Mar 2022 12:41
Thank you for the detailed tips.
For better clarity, I will summarize what is currently considered best practice:
- Use mild, pH-neutral cleaners; avoid harsh or acidic products
- Do not use abrasive sponges or brushes; instead, use soft microfiber cloths
- Use baking soda paste cautiously on stubborn stains, and always test on an inconspicuous area first
- After cleaning, always rinse thoroughly with clear water and dry
- Maintenance oils or special care products are not necessary for melamine
Do you have this clearly structured approach with any additions or critical comments? I want to make sure I care for my panels in the best possible way over the long term.
Benge5
29 Mar 2022 15:17
Togusan schrieb:
Do you still follow this clearly structured procedure, with any additions or critical comments?
The procedure follows the recommendations from technical datasheets for melamine-coated surfaces. It is also important to avoid standing water, as moisture at edges can damage the panel construction. Therefore, wipe the surfaces dry after each use.
Additionally, I would avoid using wax cloths or other materials containing plasticizers, as they can leave residues.
