Lomarika6519 Nov 2021 08:17Hello everyone, I have noticed water stains on my IKEA Malm nightstand that don’t come off even after regular wiping. The surface is lacquered, and I suspect these are white marks caused by moisture. Does anyone have experience or tips on how to effectively remove such water stains without damaging the surface? Maybe specific cleaning products or home remedies you can recommend? I’m reluctant to damage the lacquer, so I appreciate any well-founded advice.
That is really frustrating, especially with such nice furniture like the Malm. I once had the same issue with water stains on my nightstand, and I understand that you don’t want to resort to harsh cleaners. Have you tried a mixture of olive oil and vinegar? From my experience, that only slightly reduced the stains—although without causing any damage. I’m curious to see if other users have better advice.
Water stains on coated or painted surfaces, such as those on the IKEA Malm bedside table, are caused by moisture that penetrates under the paint layer or damages the finish. To remove these stains, I recommend the following approach: First, clean the surface with a soft, damp cloth and some mild dish soap. If the stains persist, you can gently polish with fine steel wool (0000 grade), but only if the surface is not a high-gloss finish, as this may dull the shine. Alternatively, specially formulated furniture polish removers for paint are available. Avoid using harsh chemicals, abrasive cleaners, or ammonia, as they can damage the paint.
As additional information: Malm nightstands are usually made of veneered particleboard with a lacquer finish, which is very sensitive to moisture. If water stains appear as white rings or cloudy spots, the top layer has been slightly raised or dulled by moisture. I recommend the following precise steps:
1. First, use a soft, slightly damp cloth without any chemical additives.
2. If there is no improvement, there are furniture care products based on beeswax that protect the lacquer.
3. For stubborn white stains: gently warmed ironing paper (do not use a steam iron) can help, with short applications, to drive out moisture trapped under the lacquer.
4. If the surface has become dull, you can polish it again with a special lacquer care product for wood.
Has anyone had experience with whether heat treatment has helped?
Joe52 schrieb:
Have you tried a mixture of olive oil and vinegar?I think these home remedies are overrated. Sure, they clean superficially, but with water stains, they often just create an illusion. Either the surface is damaged or the finish has changed. Then only repainting or replacement helps. Why always try to sugarcoat everything? Sometimes you just have to accept that furniture isn’t infinitely durable.
