ᐅ Floor Plan Design for a 150 sqm Single-Family Home – Tips for Improvement?
Created on: 22 Jan 2019 13:30
F
Franky73
we are in the process of building a single-family house with a basement suitable for living. This is the design we have come up with. I would like to hear from you if you see any possibilities for improvements.
On the ground floor, there is a side entrance door on the right. The carport will be located there.
In the basement living area, the children's rooms face south. From there, it should be possible to access the terrace and the garden.
I look forward to your tips and suggestions!
haydee schrieb:
When do you plan to use the balcony? All the time... in the evenings with a glass of wine, for sunbathing, partying with friends, and so on... and yes, I could also do all of that down on the patio or in the garden!
Well, if you already have such a spacious balcony, it would be a shame not to use it, wouldn’t it?
You need to decide for yourself whether the balcony is intended for you or for the children. The children's rooms cannot be used as passage rooms to access the balcony, and friends certainly should not have to go through the children's rooms to get there.
Sabine
Sabine
haydee schrieb:
Do you want to carry everything upstairs and then back down, when there’s a shorter way? The balcony is there after all, so in your opinion, should I just not use it?
Franky73 schrieb:
The balcony is there, so are you suggesting I shouldn’t use it?...well, it wouldn’t be that big if the master wing was upstairs... *ducks and runs*
