ᐅ Floor Plan Design for a 150 sqm Single-Family Home – Tips for Improvement?
Created on: 22 Jan 2019 13:30
Franky73
we are in the process of building a single-family house with a basement suitable for living. This is the design we have come up with. I would like to hear from you if you see any possibilities for improvements.
On the ground floor, there is a side entrance door on the right. The carport will be located there.
In the basement living area, the children's rooms face south. From there, it should be possible to access the terrace and the garden.
I look forward to your tips and suggestions!
Your bedroom is not considered a habitable room under building regulations without a window and is therefore not permitted. Just a heads-up. Thank you for the information. How large would the window need to be?
Franky73 schrieb:
Thanks for the tip. How large should the window be? A general rule of thumb is 1/10 of the room’s floor area.
Franky, you clearly have a tendency for this and you will need an architect anyway. Whether you like it or not, you have to pay for one. So let them work out the details. We will then be happy to help you with the final adjustments based on the result.
Or do you really want to spend your life sleeping in a windowless darkroom—while your heating shines brightly? That is absurd and not worth discussing.
WilhelmRo schrieb:
4. In my rental apartment from the 1990s, doors have an 80cm (31.5 inches) clear opening. Again – it’s your decision.How much clearance should or must be provided from the end of the toilet to the wall? I looked at different partition wall options, and it wasn’t more than that.
kaho674 schrieb:
Franky, you clearly have a tendency and need an architect anyway. You will pay for one, whether you want to or not. So just let them work it out. We will gladly help you with the final adjustments once you have the result.
Or do you really want to spend your life sleeping in a windowless darkroom—while your heating looks nice and bright? That’s absurd and not worth discussing. Hello Kaho, you are right, but I like to be prepared and want to know in advance if our wishes can be realized. On Friday, I/we have the meeting!
Best regards, Frank
