ᐅ Which replacement parts are most commonly needed for Ikea Hemnes furniture?
Created on: 19 Jun 2021 07:13
torybar
I am currently looking into spare parts for the Ikea Hemnes furniture range, specifically focusing on which replacement parts are most commonly needed and why.
I have noticed in several households that over time certain parts often need to be repurchased or replaced, but I lack a clear overview of which components are actually the most vulnerable.
I am particularly interested in the following points:
- Are these mostly fittings, screws, or parts like drawer runners?
- Are there known weak points that affect usability?
- Which spare parts are the easiest to order or install?
For those with hands-on experience with Hemnes or who are familiar with Ikea spare parts: Which replacement parts have you needed most often, and what tips can you share?
Thank you in advance for your answers!
Wyatt
20 Jun 2021 10:11
To answer the question "Which spare parts are most commonly needed for Ikea Hemnes?" accurately, a detailed approach is helpful:
- Hinges: Hemnes hinges are usually made of metal with plastic components. The plastic joints, in particular, tend to wear out due to regular use. Disassembly is simple, and replacement is straightforward.
- Screws: Ikea sometimes uses special sizes that are not always compatible with standard screws, so a targeted order is necessary.
- Drawer slides: In Hemnes, these are mostly metal and can jam or bend due to dust or improper loading.
Based on my own repair experience, I recommend consulting the Ikea spare parts manual and paying attention to the correct model numbers. Sometimes it is better to replace older spare parts completely rather than repairing them individually to avoid further damage.
Do you have a detailed list of the most common spare parts?
torybar
20 Jun 2021 14:37
Wyatt schrieb:
Do you have a detailed parts list for the common spare parts?
Thank you for your detailed response. Unfortunately, I have not yet found a precise parts list, which is why I started this topic here.
I am especially interested to know whether different construction types of Hemnes models (for example, dressers versus beds) tend to require specific spare parts more often, or if there are generally common wear parts that occur with similar frequency across all versions.
FEKAU
20 Jun 2021 15:26
torybar schrieb:
I am particularly interested in whether different Hemnes product types (e.g., dressers vs. beds) tend to require different replacement parts
This is indeed the case with Hemnes. Dressers most frequently require replacement parts such as drawer slides, fittings, and small screws. Beds, on the other hand, less often need replacement parts; when they do, it is usually screws for joints. So, it is fair to say that the replacement parts profile depends on the type of model.
Deoma
21 Jun 2021 08:54
The drawer runners and hinges on Hemnes dressers often break. Beds rarely require spare parts, except for screws and wooden slats.
This aligns well with what has already been mentioned.
rimole
21 Jun 2021 11:18
FEKAU schrieb:
Beds, on the other hand, rarely require replacement parts; usually, only the screws for connections are affected.
I can confirm this. For my Hemnes bed, I only had to buy replacement screws for the side connections once. Apart from that, I haven’t had any issues.
GiRoyce
21 Jun 2021 17:02
In summary:
- The most common replacement parts for Hemnes are screws, hinges, drawer slides, and rollers.
- Dressers are most prone to issues with drawer mechanisms.
- Beds mainly require screws for the frame and connections.
Owners of Hemnes furniture, especially with frequent daily use of drawers, should regularly check the slides and rollers. Early replacement helps avoid problems and extends the furniture’s lifespan.
