ᐅ How do I properly adjust IKEA HEMNES doors if they don’t fit correctly?
Created on: 16 Mar 2023 08:37
GERON63
GERON63
16 Mar 2023 08:37
Hello everyone, I recently assembled an IKEA Hemnes wardrobe and noticed that the doors don’t fit properly – they stick in some places or don’t close flush. I know that the doors in the HEMNES series come with special adjustment hinges that are supposed to allow correcting fit issues. However, I’m unsure how exactly to adjust the doors to align them correctly in height, width, and depth.
Could you please provide a detailed guide on how to properly adjust IKEA HEMNES doors when they don’t fit? Which screws need to be turned, in what order, and by how much, without risking damage to the hinges or the door?
It would also be helpful to know if there are any special considerations with this series, as the door edges seem to be somewhat delicate. Thanks in advance!
lajudo
16 Mar 2023 09:12
The door on HEMNES units can usually be adjusted using three screws on the hinges: vertically with the screw on the hinge arm, horizontally on the main part, and in depth with the screw at the top. Adjust vertically first, then horizontally, and finally the depth.
RENMA
16 Mar 2023 10:03
For the correct adjustment of IKEA HEMNES doors, I recommend the following steps:
- Ensure that all hinge screws are tightened securely by hand.
- Vertical adjustment is done via the screw on the hinge arm that controls the height. Align the door so that it sits flush and parallel to the cabinet side.
- Horizontal adjustment is made by turning the screw on the hinge cup to move the door closer to or further from the cabinet body, achieving an even gap distribution.
- Depth adjustment is done using the screw on the top of the hinge to ensure the door sits flush with the cabinet frame and does not bind.
Important: Make only small adjustments to the screws at a time and open and close the door several times between adjustments. This helps to avoid overcorrections or damage.
These hinges feature a mechanism designed specifically for fine tuning, so avoid applying excessive force when turning the screws.
DUVIN
16 Mar 2023 10:23
First tip: check if the door is properly hung. Then you can start by adjusting the height screw on the hinge arm, followed by horizontal alignment. If it sticks, slightly turn in the depth adjustment screw.
Leland
16 Mar 2023 11:01
Just as an additional note: Adjusting the hinges works better in the order of height, depth, and then width. This ensures the door is perfectly aligned at the end. This is also recommended in the IKEA instructions.
Z
zarHenning
16 Mar 2023 11:47
It is also important to retighten all screws after adjustments, but avoid overtightening. Otherwise, you can easily damage the hinges. The plastic components in the hinges are not very durable.
