ᐅ How can the IKEA Hemnes be combined with upcycled materials as a DIY project?
Created on: 5 Jun 2019 08:13
EVELIN39
EVELIN39
5 Jun 2019 08:13
Hello everyone, I am planning a DIY project to customize an IKEA Hemnes piece of furniture (for example, a dresser or nightstand) not only individually but also by combining it with upcycled materials. My goal is to blend this rather classic design with sustainable elements and recycled or reused materials in a way that keeps it functional, enhances its appearance, and at the same time makes it significantly more sustainable. What materials and techniques are particularly suitable for skillfully integrating wood, metal, fabric, or other materials? Are there any ideas for surface treatment or remodeling that can give the Hemnes furniture a completely new look without compromising stability or functionality? I look forward to suggestions and practical tips!
neoJohnny
5 Jun 2019 08:47
Good morning, the IKEA Hemnes range is primarily made of pine wood, which is well suited for surface treatments such as staining, painting, or waxing. For upcycling combinations, it is recommended to:
- Use old floorboards or planks as insets or shelves, which should be protected against moisture with clear varnish
- Reuse metal fittings (e.g., old hinges, handles) refurbished from scrap metal and installed as eye-catching features
- Incorporate textiles from used fabrics, for example as seat cushions or drawer liners
From a technical perspective, it is especially important that the own weight combined with additional materials does not compromise stability. When treating surfaces, pay attention to preventing streaks or uneven absorption of paint. For repairs or reinforcement, wood glue and appropriate screws are recommended.
barle
5 Jun 2019 09:01
Refurbishing old furniture handles, using texture paste for the surface, and adding recycled metal for the frame works well. Simple repainting also works.
RAKLO
5 Jun 2019 10:38
I specifically recommend paying attention to the different types of wood and their treatment options when combining them with upcycled materials. Hemnes pine wood is soft and absorbs paint quickly, which creates contrasting effects when used with old wood or metal parts. For example, mixing an old baking tray as a drawer front with solid pine wood can achieve an industrial look. Be sure to consider that metals might need rust protection treatment. Old fabric scraps can also be used as back panel coverings in dressers by fixing and sealing them with wood glue.
REPITAR
5 Jun 2019 12:22
To make the IKEA Hemnes furniture piece a meaningful upcycling DIY project, here is a structured guide:
1. Planning: Define which materials will be incorporated (e.g., recycled wood, metal, textile elements).
2. Preparation: Thoroughly sand the Hemnes surfaces to remove old finishes and improve adhesion.
3. Material selection and preparation:
- Wood: Adjust old boards, clean, sand, and optionally treat with wood oil or dark stain
- Metal: Remove rust, sand, and apply paint or rust protection
- Textiles: Cut fabrics to size, attach to a stable backing surface by gluing or sewing
4. Integration:
- Use tongue-and-groove joints or screws
- For metal sheets: possibly drill holes and secure with screws
- Attach fabric panels inside by gluing or stapling
5. Finishing:
- Seal surfaces with clear varnish or wax
- Ensure even drying and avoid bubbles
6. Avoid overloading to maintain the furniture’s function and stability.
Mistakes often occur when materials expand differently, so allow enough drying time and use connecting elements correctly.
Deandre
5 Jun 2019 13:55
I would like to add that upcycling projects with the Hemnes series allow for particularly striking color contrasts, such as:
- White or light primer on the main structure with old, colorful wooden parts as accents
- Attaching old moldings or frame pieces for reinforcement and decoration
I also believe that using natural materials like recycled leather for handles or upholstery adds character to the furniture and emphasizes the sustainability aspect. It is important to properly protect the surfaces before use.
