ᐅ Which replacement parts are commonly needed for IKEA Hemnes furniture?
Created on: 15 Sep 2015 08:17
Codyli
Codyli
15 Sep 2015 08:17
Hello everyone, I’m currently working on maintaining our IKEA Hemnes furniture and wondering which replacement parts are most commonly needed for this series. I’m particularly interested in whether there are typical weak points to watch out for during use, and if there are specific replacement components for Hemnes that need to be changed more often than others. Has anyone had experience with broken or worn parts on Hemnes furniture, such as beds, wardrobes, or dressers? I’m also curious about the availability and quality of the replacement parts – are they easy to order and install, or rather difficult to handle? It’s important for me to extend the furniture’s lifespan through targeted replacement without having to buy new pieces completely. Thanks for your helpful tips!
Noahlu
15 Sep 2015 09:04
Hello Codyli, your question is great because the Hemnes series is generally considered quite durable, but like any piece of furniture, there are typical wear parts. For example, the metal fittings on the bed connections often wear out—especially the angle brackets that ensure the stability of the structure. These can eventually loosen or become worn, leading to squeaking noises or instability. You should regularly check these connectors.
Additionally, the drawer slides are often weak points: the plastic or metal components that allow smooth gliding tend to lose their smoothness over time and can break. This causes drawers to stick or jam. It’s worthwhile to get new runners or rollers—these are usually available as replacement parts and are typically easy to install.
Another common issue is worn or damaged furniture feet, as they come into direct contact with the floor and can be affected by moisture or impacts. Replacement parts are generally available, but depending on the piece of furniture, they need to fit precisely. My recommendation is to always use the assembly instructions as guidance when removing and replacing parts.
Do you have specific Hemnes furniture where problems have occurred?
dusujan
15 Sep 2015 09:56
I understand that the topic of spare parts is not exactly straightforward right now – I had an issue with my Hemnes dresser where a drawer wouldn’t close properly because the drawer slides were worn out. That was quite frustrating, especially since I really value that piece of furniture. After doing some research, I ordered the exact replacement drawer runners from IKEA. The delivery was quick, and the installation was easier than expected thanks to clear instructions. At the moment, I feel confident knowing that I don’t have to replace the entire piece of furniture over minor defects. I think it’s great that IKEA provides spare parts, as it not only saves money but also helps the environment. I hope your furniture doesn’t have any major damage!
Muso4
15 Sep 2015 10:37
It's interesting how quickly some people think about replacement parts, as if Hemnes were somehow inferior. In my opinion, the IKEA Hemnes is quite sturdy, and anyone who breaks it should probably work on how they handle their furniture rather than focusing on replacement parts. Of course, some fittings wear out after many years, but that's the case with all furniture. It would be sad if you never had to make any repairs. Honestly, do you really need replacement parts that often with Hemnes? I think this topic is often overdramatized, as if there was a widespread defect.
Klakar
15 Sep 2015 11:05
With Hemnes, drawer slides are usually the most common replacement parts. Screws tend to loosen as well, so it’s a good idea to check and tighten them regularly. Protect the legs from moisture, otherwise they will swell.
Noahlu
15 Sep 2015 11:46
Muso4 schrieb:
In my opinion, the IKEA Hemnes is quite sturdy, and if someone breaks it apart, perhaps they should work on how they handle furniture rather than looking for replacement parts.
That may be true, but especially with furniture used daily, it is completely normal for wear parts to show signs of deterioration. I’m not saying that Hemnes is low quality, but rather that preventive measures should be taken to extend its durability. Regularly checking connectors and replacing worn-out drawer slides are steps that make sense in the long run. It’s about maintenance, not carelessness. Have you had different experiences with certain parts?
Regarding the feet, there is the additional issue that they can swell when in direct contact with moisture, as already mentioned here. Therefore, it’s worth using vapor barriers or felt pads.
