ᐅ What alternatives are there for assembling IKEA Hemnes furniture?
Created on: 29 Jan 2022 08:42
maura56
maura56
29 Jan 2022 08:42
Hello everyone, I recently bought the IKEA Hemnes furniture piece and have a question regarding its assembly: What alternatives are there for putting together the IKEA Hemnes? I am especially interested in approaches that differ from the standard assembly instructions, such as different assembly methods, tools, or useful tips to know for making the furniture more stable or easier to build. I want to avoid just strictly following the manual and instead learn more about possible options. Maybe you also have experience with self-modified assemblies, special fastening methods, or alternative joinery techniques? Looking forward to your tips and discussions.
dosogau
29 Jan 2022 09:37
Hello, as an alternative to the standard assembly, you can use wood screws and wood glue instead of the included nails and dowels for increased stability. This significantly improves durability. It also helps to assemble the furniture on a soft surface.
TEBILO
29 Jan 2022 11:23
Very interesting approach to the question! When assembling IKEA Hemnes furniture, it is indeed worthwhile to consider some technical alternatives. First, I recommend not following the included instructions blindly but understanding each joint beforehand. Most pieces in the Hemnes series use a combination of dowels, furniture bolts, and back panels that are glued and nailed.
A common alternative is to join the parts using high-quality wooden strips with biscuit joints instead of conventional dowels, resulting in a firmer and more durable connection. Using clamps during the glue-drying process is also helpful to prevent warping.
It is also important to mark and align all parts precisely before assembly, as even slight inaccuracies can cause issues later with doors or drawers. Another alternative is to reinforce heavily loaded areas, such as shelves, with additional metal brackets for greater stability.
I would be interested to know if you have any specific purposes or use scenarios that require particular assembly considerations?
maura56
29 Jan 2022 12:07
TEBILO schrieb:
I would like to know if you have any specific purposes or use scenarios that impose particular requirements on the construction?
Thank you for the detailed advice! Yes, my Hemnes will mainly be used as a bookshelf and needs to support a lot of weight – so I don’t want to compromise on stability. Also, I am trying to avoid standard nail and dowel joints where possible because I’m concerned they might loosen over time. It would be great if the furniture could also withstand a small move.
kibutar
29 Jan 2022 13:51
Hello maura56, since you plan to use your Hemnes primarily as a bookshelf with a high load capacity, I recommend considering the following alternative measures:
- Instead of dowels and nails: secure with strong screws, ideally wood screws with a countersunk head, to ensure better tensile strength.
- Use wood glue additionally to ensure a solid bond.
- To improve stability, consider doubling the back panel or reinforcing it with metal brackets.
- Shelves carrying heavy loads can be supported with additional brackets or stronger supports.
- To prevent loosening during frequent movement (moving house, transport), it is advisable to reinforce all joints multiple times, for example by pre-drilling and proper screwing.
Are you reasonably skilled with DIY? If so, I can also give you specific recommendations on suitable screw sizes and brackets.
dosogau
29 Jan 2022 14:29
kibutar schrieb:
To prevent loosening from frequent movement (relocation, transport), it is recommended to secure all connections multiple times, for example by pre-drilling and proper screwing.
Exactly, pre-drilling is important. Be sure to choose screws longer than the anchor depth, otherwise it won’t hold properly.
