ᐅ Can I repurpose Ikea Hemnes shelves for outdoor furniture storage?
Created on: 7 Jul 2024 09:12
alperHello everyone,
I have the following question: I would like to know if Ikea Hemnes shelves – specifically the free-standing shelves from the Hemnes series – can be repurposed effectively to store garden furniture or garden items such as cushions, smaller tools, or plant pots in a weather-protected way.
My main concern is durability and load capacity under the often significantly changing weather conditions, such as rain, sunlight, and humidity. I wonder if the typical finish and wood quality of the Hemnes shelves can reasonably withstand these outdoor conditions or if I might encounter long-term issues like warping, mold, or chipping.
I am also interested if anyone has experience improving these shelves for outdoor use through additional treatments or modifications.
In short: Can I use Ikea Hemnes shelves safely, or at least with certain precautions, for garden storage purposes, or would it be better to choose specially weather-resistant outdoor shelving instead?
Thanks in advance for your opinions!
Hello Alper,
Your question is very good and important because indoor furniture is usually not designed for outdoor weather conditions.
Hemnes shelves are mostly made of solid pine wood, which is sturdy but untreated or only coated with standard lacquer is not suitable for permanent outdoor use.
With moisture, the wood can swell, warp, or absorb moisture, which can in turn promote mold growth.
If you want to use Hemnes shelves in your garden, you should definitely:
- treat the surfaces with weather-resistant wood oil or special clear varnish for outdoor use,
- protect the shelf base against standing water (e.g., with waterproofing or rubber pads),
- place the shelf in a wind-protected and ideally covered area,
- regularly inspect and, if necessary, re-treat the wood.
Only then do you have a reasonable chance to use the shelves in a garden or patio area for a longer period.
In general, however, they are not designed as outdoor furniture.
flo-Theres7 Jul 2024 10:13Hello everyone,
I want to address the technical aspect: Ikea Hemnes shelves are designed for indoor use, so the finish is generally not UV-resistant and not waterproof enough for outdoor use. Although pine is relatively durable, it will clearly suffer if not properly protected.
Using them permanently in the garden without appropriate pre-treatment or cover usually leads to visible damage within the first few months.
My advice: If you cannot store them under a permanent cover, consider specially treated outdoor shelves or metal shelves with coated surfaces. These are much better suited to withstand weather conditions.
Nathanaelk7 Jul 2024 11:02Hello alper,
I understand your question well and would like to provide a detailed answer. The Hemnes shelves are made of solid pine, usually sealed with a lacquer designed primarily for indoor use.
Issues when using them outdoors:
- Wood reacts to moisture, meaning it expands and contracts. Without proper protective coatings and construction measures, this can quickly lead to cracks or warping.
- Hemnes shelves generally do not have impregnation to protect the wood against rot or fungal infestation. Once moisture penetrates for an extended period, mold is a likely outcome.
- UV radiation breaks down the lacquer over time, causing flakes and graying.
What you can do to prepare the shelves for outdoor use:
1. Remove the indoor lacquer or at least thoroughly sand the surfaces.
2. Apply several coats of wood preservative or oil with UV protection that is certified for exterior use.
3. Seal the top and bottom edges with sealing tape or silicone to minimize water ingress.
4. Place the cabinet in a sheltered location, for example, under a canopy.
Also important: Check the shelves regularly, as repairs may be necessary.
In conclusion: For occasional use, such as seasonal or covered use, with treatment, it can work. For permanent outdoor use, these shelves are not ideal.
warrenka577 Jul 2024 11:46Hello everyone,
I really like this topic because I had similar thoughts before and actually used Hemnes shelves on my patio.
After about two summers, some damage became inevitable. Especially on the edges, the paint started to peel, and moisture got through the back panel. My shelves were partly covered but not fully protected.
For me, it was also a learning process. I think it’s important to try to keep moisture away, for example by using rubber feet, protective shelf liners, or placing shelves made of water-resistant materials. Plastic boxes in the shelves then helped to better protect devices and cushions.
In general, I would recommend using Hemnes outdoors only if you are willing to invest regular maintenance.
