ᐅ Which maintenance products are recommended for Ikea HEMNES furniture?
Created on: 14 Apr 2020 08:37
SanpiI recently acquired a piece of furniture from the Ikea Hemnes series, specifically a white-stained sideboard. Since I place great importance on the durability and care of this wooden furniture, I would like to know: which cleaning and maintenance products are suitable for Ikea HEMNES to protect the piece long-term from wear, moisture, and discoloration? I am particularly interested in recommendations for appropriate cleaners, care products, or oils that do not damage the surface and ideally complement the typical stained wood appearance. Are there specific products that are well suited for regular maintenance cleaning? Or possibly natural home remedies that can be used safely without harming the material? I look forward to well-founded advice from you, including experiences and any warnings.
Leonardteo14 Apr 2020 09:22For the care of Ikea HEMNES furniture, I recommend using neutral cleaning agents that do not contain aggressive solvents or abrasives. The glazed surface benefits from gentle cleaning with a soft, damp cloth and mild soap. It is also advisable to use wood care products specifically designed for glazed or painted wood to maintain the protective layer. I personally sometimes use a linseed oil-based wood care oil, which sustainably nourishes the surface without causing discoloration.
The question of suitable care products for the Ikea HEMNES range is quite complex, as the natural wood grain must be considered alongside the glazed surface. Fundamentally, HEMNES is made of solid pine wood, which is quite sensitive to moisture and mechanical stress. Although the glaze seals the surface, it does not provide complete protection against liquids or dirt. Therefore, I recommend the following approach for care and cleaning:
- For daily cleaning: Use a microfiber cloth lightly dampened with warm water and a mild, pH-neutral dish soap. Avoid harsh or alcohol-based cleaners, as they can damage the glaze.
- For occasional care: Special wood care products designed for glazed surfaces that create a light protective film help minimize abrasion and scratches. These products should be water-based to preserve the wood’s breathability.
- Avoid oil- and wax-based care products intended for oiled wood. These penetrate the surface and can cause unwanted stains or uneven shine on a glazed finish.
- Stains or more significant dirt are best removed with a gentle eraser or a fine sponge, never with sandpaper.
Could you possibly describe in more detail how heavily the furniture is used? Is it located in a damp room or rather in a living room? The area of use greatly influences the choice of products.
kulau schrieb:
Could you perhaps describe in more detail how heavily the piece of furniture is used? Is it located in a damp room or rather in a living room?The sideboard is located in my living room, so it is not a damp room, but it is used frequently, for example as a surface for decorations and occasionally for drinks or snacks. The surface should remain visually well preserved and also be as resistant as possible to minor scratches and stains. How often should the recommended maintenance be applied if there is no visible dirt, but rather to work preventively?
In a living room without direct moisture exposure, it is sufficient to clean and maintain the furniture every few months. Simply wipe it with a lightly dampened cloth and apply a special care product for lacquered wood surfaces every 3-4 months. Follow the manufacturer's instructions carefully.
In summary, I recommend the following product strategy for Ikea HEMNES furniture:
- Cleaning: Mild, pH-neutral cleaning agents, no abrasive cleaners
- Maintenance: Wood care products specifically designed for lacquered surfaces, typically water-based
- Frequency of use: Every 3 to 6 months, depending on usage
Avoid oils or waxes, as they can negatively affect the lacquered surface. The surface is also not suitable for strong solvents, so do not use alcohol-based cleaners or vinegar.
Regular dusting also helps protect against scratches.
If desired, I can provide some example products that have proven effective in practice.
