I am considering using my Ikea Hemnes furniture in a damp area, specifically in the bathroom. The furniture is made of pine wood, which is generally not ideal for constant exposure to moisture. My question is: How can the Ikea Hemnes furniture be best prepared or treated to make it suitable for use in damp rooms without damage or swelling? Are there proven methods, such as specific paints, sealants, or other protective measures that are effective? I would appreciate any experience, practical tips, and advice on proper maintenance. Thanks in advance!
Fejoli schrieb:
How can the Ikea Hemnes furniture be best prepared or treated to make it suitable for use in damp rooms without getting damaged or swelling? I completely understand wanting to protect your furniture, as Hemnes is truly a beautiful piece. I once tried using a Hemnes in the bathroom without any treatment – that was a mistake, as it did warp and swell in some areas.
What I learned is that a thorough sealing is essential, especially on all edges and also on the back panel and bottom. You might want to consider water-repellent varnishes or special wood stains designed for moisture resistance. Have you thought about fully oiling or painting the wood? Looking forward to hearing more opinions!
Fejoli schrieb:
Are there any proven methods for which paints, sealants, or other protective measures are useful?For Hemnes made of pine wood, I recommend the following approach:
- Sand all parts before assembly (grit 120 to 220)
- Then apply a primer or sealing primer that repels moisture
- After that, apply at least two coats of a high-quality, waterproof polyurethane (PU) varnish
- Especially important: treat edges, drill holes, and the back multiple times
- Don’t forget the interior surfaces before treatment, as humidity also comes from inside
- Alternatively, an oil-wax finish can be used, which repels moisture while allowing the wood to breathe
Make sure the varnish complies with relevant standards (e.g., DIN) regarding moisture resistance.
This process takes time but provides long-lasting protection for the furniture in the bathroom.
DRAKE70 schrieb:
Alternatively, an oil wax can be used, which repels moisture while keeping the wood breathable.The idea of using oil wax sounds very interesting. I was initially concerned that varnish would make the furniture look too sterile. Has anyone had experience with oil waxes or similar products on Hemnes?
