ᐅ How can the IKEA Hemnes furniture be best protected during frequent moves?
Created on: 8 Sep 2022 08:37
ellineo
ellineo
8 Sep 2022 08:37
Hello everyone, I hope to find some helpful tips here in the forum: How can the popular IKEA Hemnes furniture be protected to remain as undamaged as possible during frequent moves?
I’m not just concerned about a single transport but about moving every 1-2 years, repeatedly disassembling, reassembling, and transporting the furniture. I want to avoid damage to screws, hinges, or the wood, as well as loss of stability. Which packaging methods, protective materials, or even structural modifications would you recommend to keep the Hemnes furniture durable in the long term?
Are there any proven tricks for disassembly that make reassembly easier and safer later on? And what’s the best way to protect surfaces and edges, especially when the furniture is regularly moved to different environments?
I appreciate any suggestions, including practical examples from your own moving experience.
farje
8 Sep 2022 09:12
ellineo schrieb:
How can you protect the popular IKEA Hemnes furniture so that it remains as undamaged as possible during frequent moves?
Basically, I wonder how much protection is really necessary – Hemnes is quite sturdy, but furniture that is frequently taken apart and reassembled will naturally lose some stability. My experience shows that careful documentation of screws and parts is much more important than extensive padding.
You should also consider whether you want to keep using the original wood and original fasteners every time, or if replacement fittings for the movable parts can be purchased that offer greater durability.
Furthermore, you should carefully think about which protective materials are truly helpful – bubble wrap is good for delicate surfaces, but reinforced strapping around the edges offers better protection than any kind of padding. A smart setup in sturdy furniture crates that don’t shift is often even more effective.
eldubi
8 Sep 2022 11:03
Always label all parts individually and collect screws in small bags, then attach these to the respective furniture part.
Placing felt pads underneath protects against scratches.
Protect corners with foam during transport, especially for doors.
gadalu
8 Sep 2022 14:45
To optimally protect the IKEA Hemnes during frequent moves, I recommend the following systematic approach:
- Disassembly: Immediately after disassembly, sort and label screws and small parts, and store them in lockable containers. A screw plan with photos makes reassembly easier later.
- Transport: For delicate surfaces, breathable cotton furniture covers are recommended to prevent scratches and reduce moisture.
- Edge and corner protection: Special foam edge protectors or flexible padding strips help protect against impacts.
- Storage: If possible, store in dry, temperature-controlled environments to prevent wood warping.
- Assembly: When reassembling repeatedly, avoid tightening connections too much to prevent material fatigue.
At the same time, I advise against using cheap protective films, as these can trap moisture and damage the wood.
NOAHSAU
8 Sep 2022 16:22
I am already bothered by the basic assumption that Hemnes is permanently ideal for frequent moves. This is standard IKEA mass-produced furniture, not high-performance furniture.
gadalu schrieb:
Disassembly: Store screws and small parts sorted and labeled in lockable containers immediately after disassembly.
Of course, that’s basic knowledge. But honestly: if you can’t manage that, why move so often with such furniture?
My advice: better sell the Hemnes and buy new furniture with your next move. The savings in stress and time are huge.
Or put differently: if you can’t take care of your furniture like a battleship, why expect it to last? Eventually, every plug-in joint reaches its limit.
ellineo
9 Sep 2022 07:17
NOAHSAU schrieb:
Or in other words: If you can’t handle your furniture like a battleship, why do you expect it to last?
Thanks for the honest new perspective! Of course, no one is saying that Hemnes is a high-end moving furniture. Still, my current goal is to extend its lifespan with as little extra cost and effort as possible. Buying new furniture for every move is neither sustainable nor economical.
eldubi schrieb:
Always label every part individually and collect screws in small bags, then attach them to the relevant furniture part.
I generally do it that way, but I would appreciate tips on how to organize this faster and more reliably, especially under the stress of moving day.
Are there any clever systems or standardized packaging that make this easier?
