ᐅ How can the IKEA Hemnes furniture be made to last longer with simple adjustments?
Created on: 1 Apr 2022 08:23
Fuleke
Fuleke
1 Apr 2022 08:23
I recently bought an IKEA Hemnes wardrobe and have already noticed that some parts, especially the doors and drawers, tend to loosen over time. I am very interested in how this popular furniture classic can be made more durable with simple measures. What actions, such as regularly tightening screws, avoiding high humidity, or other care tips, have proven effective in practice? Are there any preventative tips to ensure the wardrobe stays stable from the start? My goal is to keep the Hemnes in good condition for as long as possible without having to constantly repair it. I look forward to well-founded and practically tested advice.
Lis53
1 Apr 2022 09:15
Hello, to extend the lifespan of an IKEA Hemnes cabinet, I recommend the following measures:
- Regularly tighten screws and connectors, as wood naturally expands and contracts. Once every quarter should be sufficient.
- Avoid high humidity, as solid wood can swell and get damaged.
- Use coasters or felt pads under heavy objects to prevent pressure marks.
- Treat the surfaces once or twice a year with an appropriate wood care product to protect against moisture and dirt.
By following these simple steps, the cabinet can remain stable and attractive for a very long time.
Ryder35
1 Apr 2022 10:02
Regularly tighten screws.
Avoid moisture.
Maintain surfaces.
BENBI
1 Apr 2022 11:49
Basically, the Hemnes is made of solid pine wood, which is durable but also reacts to moisture and changing climate conditions. For long-lasting use, I recommend the following approach:
- When assembling, make sure to tighten all screws carefully but firmly, using a torque that prevents over-tightening to avoid damaging the wood.
- Once the wardrobe is assembled, check all fittings after about 4 weeks and then regularly every 3 months, as screws on door hinges and drawer slides tend to loosen.
- Maintain indoor humidity at a stable level around 40-60% to prevent swelling and shrinking.
- For the surface, I recommend natural wax or a wood oil that protects the grain while remaining breathable. Plastic-coated care products are generally not recommended long-term, as they seal the wood and can cause cracking.
- A common mistake is overloading the drawers. Pay attention to the maximum weight, and if possible, store heavy items on the wardrobe floor or on the sides.
Have you already noticed any specific damage? Then we could address it more precisely.
Fuleke
1 Apr 2022 12:37
BENBI schrieb:
Have any specific damages occurred for you yet? That way, we could address them more precisely.
Thank you for the detailed response. Specifically, I have noticed that the drawers start to give slightly at the corners, and the door hinges develop some play after only a few months of use. In addition, the wood on the underside of the doors seems to warp slightly, probably due to moisture in the apartment. I’m wondering if adding reinforcements or moisture protection could improve durability without compromising the cabinet’s style.
LOGEMIN
1 Apr 2022 13:21
To stabilize the drawers, I recommend occasionally wiping the runners with a dry cloth to remove dust and applying a thin layer of wax (e.g., beeswax) if needed. This reduces friction and helps prevent damage over time.
The hinges can be replaced with suitable stainless steel screws, which offer better durability – these are discreet and do not affect the design.
For the wooden pull handles on the underside of the doors, a thin layer of transparent wood preservative or a breathable clear varnish can help protect against moisture. Be careful not to apply the coating too thickly, as this can damage the wood grain.
Additionally, I suggest protecting furniture from dry indoor heating air in winter or using a humidifier to better balance moisture levels.
