ᐅ Are there DIY alternatives for Ikea HEMNES finishes?
Created on: 10 Jun 2023 13:17
Rensan32
Rensan32
10 Jun 2023 13:17
Hello everyone, I hope there are some people here who are knowledgeable about furniture and DIY projects. I own several pieces from the Ikea Hemnes series and have long been unsatisfied with the finish—mainly because it is quite prone to scratches and stains. Now I’m wondering if there are any recommended DIY alternatives or improvements for the surfaces of HEMNES furniture that can match or even surpass the look and feel of the original. I’m particularly interested in whether different materials or techniques are suitable for increasing durability and possibly changing the style, without needing to use professional workshop services. Do you have experience with such methods? Which DIY approaches work well, and what should be avoided?
Elodie
10 Jun 2023 14:02
Hey Rensan32, great question! I think the topic of “DIY alternatives for Ikea HEMNES finishes” is perfect for adding a bit of color and creativity. Many people use chalk paint or specialized furniture paint because it’s easy to apply and gives the furniture a unique look. 🤩
You can also work with waxes or oils, which protect the surface while often leaving a nice matte sheen. The important thing is to sand the surface well beforehand so the paint or oil adheres properly.
Sometimes an affordable alternative for maintenance is enough and can even look more original than the typical HEMNES white!
gesar32
10 Jun 2023 14:45
Additional information: HEMNES surfaces are usually painted or coated with melamine resin, resulting in a smooth, protective layer. DIY methods such as applying chalk paint or separate oils often permanently alter the surface and can reduce durability if not done properly.
A reliable option is using acrylic paint combined with a hard wax oil as a protective finish. Intermediate sanding should always be performed to ensure adhesion and a good final result.
Conclusion: DIY is possible – but requires careful planning and preparation.
Aimee
10 Jun 2023 15:10
The surfaces of HEMNES can be sanded down and treated with furniture wax. This provides good protection and lasts for quite a long time.
TRADI
10 Jun 2023 16:28
To explain this in more detail: The HEMNES series mostly uses solid pine wood with either a lacquer coating or a type of melamine foil, depending on the piece. For DIY alternatives, it depends on whether you want to preserve the original look or change it.
If you want to keep the look, a gentle sanding followed by the application of a transparent, matte, or satin-matte wood stain or furniture oil would be appropriate. The wood pores should not be sealed to maintain the wood’s breathability.
If you want a new color or a completely different style, you can sand the surface down entirely and then repaint it. Acrylic or chalk paints with a suitable sealing wax are recommended in this case.
It should be noted that surfaces fully covered with paint may be more prone to damage if they are not professionally sealed.
We are also happy to discuss special tools or intermediate treatments if desired.
Rensan32
10 Jun 2023 16:45
gesar32 schrieb:
DIY methods such as applying chalk paint or separate oils usually alter the surface permanently and can reduce durability
Thanks for the advice, gesar32. I’m especially interested in whether there is experience with how durable these surfaces really are after treatment. What are the limits, for example, with chalk paint? Does the piece of furniture remain practical for everyday use, especially with frequent use in living areas?
