ᐅ How can I treat Ikea Hemnes material with water repellent or wood preservative?
Created on: 18 May 2022 09:12
KAUBLA
KAUBLA
18 May 2022 09:12
I recently purchased a Hemnes piece of furniture from Ikea, which is mainly made of solid pine wood. Since this material is new to me, I want to protect it as well as possible, especially against moisture and general wear. My specific question is: How can I properly treat the material of an Ikea Hemnes furniture piece with a water or wood protector without affecting the appearance or wood grain? Are there any recommended products or specific methods to consider?
I look forward to your experiences and tips!
mabla
18 May 2022 09:35
I would recommend a water-based clear coat, especially if you want to preserve the natural look. Lightly sand beforehand and then apply a thin layer.
Dirkmin
18 May 2022 10:02
The Hemnes furniture is made of solid pine, which can be sensitive to moisture. For effective protection, I recommend:
- First, thoroughly sand the piece (grit about 120-180) to ensure good adhesion.
- Then apply a primer or wood preservative stain that repels moisture.
- Finally, apply several thin coats of a water-based clear varnish or wood protective oil.
This combination protects against water and preserves the natural feel better than using varnish alone.
kulau
18 May 2022 11:17
Hello KAUBLA,
since you are specifically referring to Ikea Hemnes furniture, here is a detailed guide on how to best protect the pine wood:
- Preparation: Hemnes parts often have a thin protective coating that you should carefully remove before treatment using sandpaper with a grit of 180-220 to allow the new products to penetrate well.
- Choice of product:
- Water-based wood preservatives have the advantage of being low odor, drying quickly, and not yellowing the wood.
- Oils (e.g., linseed oil or special wood oils) penetrate deeply into the wood and provide natural protection but need to be reapplied regularly.
- Water-based clear varnishes are more resistant to moisture, slightly alter the wood texture visually, and usually have a glossy or satin finish.
- Application:
1. Sand the wood well and remove all dust.
2. Apply a thin layer of the chosen product with a brush or roller.
3. Allow to dry (follow manufacturer’s instructions).
4. If needed, lightly sand again and apply a second coat.
- Important tip: Test the product first on an inconspicuous spot, as pine wood can react very differently, especially in terms of color.
- Alternative: For surfaces exposed to high wear and tear (e.g., tabletops), I would recommend a combination of wood oil and varnish – oil first, then several layers of varnish.
If you can provide more details about usage or location, I can tailor the recommendation more precisely!
FAVALERIE9
18 May 2022 12:08
The best protection is to first sand the wood, then apply a water-based wood oil. This preserves the wood’s natural color and provides water resistance.
KAUBLA
18 May 2022 13:47
kulau schrieb:
If you can provide more details about the usage or location, I can tailor the recommendation more precisely!
Thank you for the detailed post!
The piece of furniture is a Hemnes TV bench, located in the living room, and occasionally exposed to minor moisture – for example, small water splashes or slight humidity from the indoor climate. Visually, it is important to preserve the light pine as much as possible without strong yellowing, and the surface should feel as natural as possible, so no thick varnish layers with a plastic-like feel.
I also want to avoid constant maintenance, but a little care every few years would be acceptable.
Do you perhaps have a recommendation for which wood finish would be best suited for this specific use and these requirements?
