ᐅ How durable are IKEA Hemnes furniture pieces with everyday use?
Created on: 7 Oct 2023 08:37
Sinaless47
Sinaless47
7 Oct 2023 08:37
I am planning to purchase some furniture from the IKEA Hemnes series for my home, especially bedroom furniture and a few small sideboards. I am very interested in how well these Hemnes pieces actually hold up with daily use. In particular, I want to know about aspects such as material quality, stability after prolonged use, effects of frequent opening and closing of drawers, as well as overall durability and ease of maintenance.
Are there any experiences from people who use this furniture daily? How does the Hemnes series compare to other IKEA lines or furniture in a similar price range in general? I am not expecting high-performance cabinet furniture, but it would be important to know if they are suitable for regular use without showing visible signs of wear or loss of functionality after a short time.
I look forward to your assessments and experiences!
Ethan
7 Oct 2023 09:12
Hello Sinaless47,
I find your question very important because furniture in everyday use is often subjected to more wear and tear than expected.
From my experience and that of several users I know: the Hemnes series is quite sturdy, mainly because it is mostly made of solid wood, which makes it more durable than many other IKEA lines that often use particleboard.
Regarding daily use:
- The drawers and doors hold up well even with frequent opening, as long as they are properly assembled.
- Scratches and minor signs of wear are more noticeable on the painted surface, which is normal for solid wood.
- Maintenance with mild cleaners and occasional oiling or waxing extends its lifespan.
In comparison: Hemnes is certainly one of the more durable options at IKEA, although the prices are somewhat higher than the more affordable series; you pay for the quality.
If you value sustainability and solid craftsmanship, Hemnes makes sense, but with very heavy use, small signs of wear may eventually appear. I hope this helps you for now!
nubar
7 Oct 2023 10:45
I agree with Ethan’s point and would like to add that with Hemnes furniture, the joints and screw connections are particularly important. If assembled incorrectly or taken apart too often, the furniture can lose stability.
Another aspect is the surface coating. Hemnes uses painted pine wood, which looks nice but can react under heavy load or moisture. Therefore, it is essential to use moisture-resistant care products and avoid direct sunlight exposure.
I would also advise against placing excessive weight on the shelves, as the wood could bend if overloaded for extended periods.
If anyone has specific areas that are subject to especially high mechanical stress, it would be helpful to know in order to provide more targeted advice.
kulau
7 Oct 2023 12:16
I would like to take a closer look at the material structure and long-term stress to better assess the Hemnes series.
The Hemnes series is mostly made of solid pine wood with a lacquer finish. Solid wood means, in contrast to particleboard or MDF, that the furniture responds significantly better to mechanical stress, with regard to strength and elasticity. On the other hand, pine wood reacts more to changes in humidity and temperature than harder woods.
Regarding the construction:
- Screws are inserted into pre-drilled holes, but the wood is relatively soft. When disassembling the joints, the material can be damaged.
- Some components have concealed metal fittings, which are quite sturdy – however, the combination with the wood thickness is crucial for stability.
The drawer mechanisms are particularly critical under daily use. The drawer slides are usually metal, but the wood surrounding them carries the weight. Over time, signs of wear and slight warping may occur here.
Care instructions:
- Regularly tightening the screws can help maintain the furniture’s stability for a longer time.
- For long-term users, I also recommend occasionally checking the surfaces and refreshing them with wood care products.
How often and how heavily do you expect to use your furniture? This information could help provide more precise recommendations.
Sinaless47
7 Oct 2023 13:04
kulau schrieb:
How often and how intensively do you expect your furniture to be used?
Good question! I plan to use the bedroom furniture daily, so drawers and cabinets will be opened and closed several times a day. The sideboard will be used in the dining room for dishes and glasses—also regular use, but not constantly. I don’t have children, but I do have pets that might scratch the furniture—mostly a cosmetic concern.
I find your advice about checking screws and wood maintenance very important, as I don’t want any loose parts. Are there any experiences on how often one should tighten screws or perform maintenance to keep the furniture stable even after a few years?
Goixkin
7 Oct 2023 13:18
Please note:
- Hemnes withstands daily use well if the furniture is assembled properly.
- Check screws every 6 months.
- Protect the furniture from moisture and direct sunlight as much as possible.
- Consider scratch protection for pets, as pine wood is soft.
So it works well in normal households.
