ᐅ What to do if IKEA Hemnes screws are missing?
Created on: 9 May 2018 18:23
ixjachen
ixjachen
9 May 2018 18:23
I recently ordered and assembled an IKEA Hemnes piece of furniture, but I found that some important screws were missing in my delivery. The specific screws in question are the long metal connectors needed to securely join the individual panels (the official term in the instructions is "metal screw with thread" or "connecting bolt").
Since I don’t want to leave the furniture incomplete or unstable, and I assume this might happen to others as well, I wanted to ask:
What do you recommend doing if screws are missing from an IKEA Hemnes?
- Should you contact IKEA directly, or are there quicker alternative solutions?
- Are there compatible replacement screws available at hardware stores that can be used?
- How do you handle possible delays due to replacement shipments?
I look forward to your tips and experiences, especially any advice on the best way to contact IKEA or whether there are certain types of screws that can be safely omitted.
Thanks in advance!
Kabau
9 May 2018 18:29
Always contact IKEA directly and provide the item number. They usually send missing screws free of charge.
Peone
9 May 2018 18:41
I completely agree with Kabau. It’s best to send IKEA an email with the product details, preferably including the exact screw designation or even the item number of the furniture series. They usually replace missing parts quickly.
If the waiting time is too long, as a temporary solution you can use comparable screws from a hardware store – but make sure they have the exact same size and thread type to ensure everything remains safe and stable.
Be cautious of cheap products that don’t have the right material or adequate strength.
jokau
9 May 2018 18:48
Measure the screws exactly, then get matching ones at the hardware store. IKEA replacements take too long.
ixjachen
9 May 2018 19:02
Peone schrieb:
If the waiting time is too long, as a short-term solution you can use comparable screws from a hardware store – but you must make sure they have the same size and thread type to ensure everything remains safe and stable.
Be cautious with cheap products that do not have the right material or appropriate strength.
Thanks for the advice, Peone.
Could you please explain the best way to accurately determine the size and thread type? I have a caliper on hand, but I’m not sure which parameters are the most important – diameter? Length? Thread pitch?
I want to avoid damaging the furniture part or making it unstable due to incorrect screws.
Peone
9 May 2018 19:19
Hello again,
Yes, a caliper is perfect. First, measure the outer diameter of the screw shaft, as this is crucial for selecting the correct screw size (e.g., M6, M8, etc.).
Next, determine the thread pitch – there are special thread gauges for this, but often a photo comparison at a hardware store can help. The length of the screw is also important, since screws that are too short won’t provide a stable connection, and screws that are too long can damage the building materials.
If you’re unsure about bringing the caliper with you to the hardware store, this is the best approach. Also mention which piece of furniture and which connection the screw is for; many staff are familiar with the IKEA Hemnes series.
One more thing: IKEA often offers sets with replacement fittings, which you can order as well.
Hope this helps!
