ᐅ When do common issues with IKEA HEMNES typically arise, and how can they be resolved?
Created on: 27 May 2023 09:17
siegbert10
siegbert10
27 May 2023 09:17
Lately, I have been reading more frequently about problems with the IKEA Hemnes furniture system and would like to start a detailed discussion here: When do common issues with IKEA HEMNES typically occur, and what are the most effective ways to address them? I am especially interested in gathering experience regarding whether these problems arise during assembly, everyday use, or only after a certain period of use. What specific weaknesses are known (for example, material quality, fit accuracy, durability of fasteners), and what is the best approach when these problems appear? I look forward to well-founded assessments and practical solutions, as I am currently assembling a dresser from this series and want to identify potential issues early on.
Lucien
27 May 2023 09:46
Typical issues with IKEA HEMNES furniture mainly occur during assembly and after prolonged use. The most common problems include:
- Inaccurate drill holes that make screw connections difficult
- Warping of wooden parts due to moisture or temperature changes
- Loose doors or drawers, which often appear after several months of use
To prevent or resolve these issues, I recommend:
- Careful preparation of the parts before assembly
- Using a cordless screwdriver with torque control
- Retightening screws and hinges after about six months
- Protecting the furniture from moisture and direct sunlight
These recommendations are well supported by numerous practical reports.
Nakar33
27 May 2023 10:12
To examine the topic in more detail, I would like to share my experience with the HEMNES series, specifically the three-door wardrobe and the chest of drawers. Assembly issues often start with handling the solid wood parts: due to the use of pine wood, the panels react to moisture and humidity with slight swelling. This often causes stress at the joints. If a drill hole is not precisely positioned or if the wood cut is slightly warped, assembly becomes unnecessarily difficult.
Technically, I recommend the following:
- Lightly sand all parts before assembly (light sanding on the contact surfaces)
- Re-drill holes with a drill bit of about 5mm (approximately 0.2 inches) to avoid tight spots
- Tighten screws with consistent torque to avoid damaging the wood
After assembly, long-term issues with HEMNES include loosening of fittings and drawer slides, as these are primarily made of plastic. These components age over time, which promotes shaking or doors becoming misaligned.
If these points are ignored, time-consuming rework is often necessary, such as replacing individual fitting parts or readjusting hinges, ideally at least once a year. In cases of significant wood deformation, horizontal braces or the use of wood preservatives can help stabilize the structure.
Ramon4
27 May 2023 11:05
About a year ago, I assembled a HEMNES wardrobe and would like to share my personal experience. The problems only appeared after about 3-4 months of regular use. The doors became less smooth to open and close, which was due to the hinges – however, these can be easily adjusted using the included Allen key.
Additionally, the drawers were not always perfectly flush; this was because I had not fully tightened a screw during assembly. My advice is to take your time with every screw and check the alignment step by step. I find the quality of the pine wood to be good, although I keep the furniture in a room with a relatively constant temperature to minimize warping.
Question: Did you notice these issues mostly during assembly or mainly during use? That might help in providing more targeted advice.
Kukar
27 May 2023 11:27
The most common problems are loosening screws and parts that do not fit perfectly. Especially doors and drawers often require adjustment later on. Simply retighten all screws regularly.
siegbert10
27 May 2023 11:43
Ramon4 schrieb:
Question: Do the problems occur more during the assembly phase or mainly during use?
Thank you for asking. Both phases are actually important to me. Assembly is still ongoing, but I want to make sure that I can identify material defects or fitting inaccuracies early on. Regarding use, I am especially interested in how to recognize typical signs of wear and which assembly steps can help prevent issues to keep the furniture stable for longer. Any necessary adjustments should be as simple and manageable as possible. Do you have specific tool recommendations or do you prefer certain methods?
