ᐅ Are there weight limits for IKEA Hemnes drawers?
Created on: 15 Nov 2022 08:17
Timichen
I have a question regarding the load limits for IKEA Hemnes drawers. Specifically, I am interested in whether there are official specifications or recommendations from IKEA about the maximum weight each drawer in the Hemnes series can hold.
I plan to use the drawers for heavier items, such as file folders or kitchen utensils. Therefore, it is important for me to know if the drawers can safely support a certain weight without damage or affecting their functionality.
Does anyone have experience with this or can point to sources that provide information about the maximum load capacity of these drawers? I am also interested in practical tips for care and use to ensure their durability.
Thanks in advance!
sanjon
15 Nov 2022 11:40
In short: IKEA does not provide official specifications for the Hemnes drawers.
In practice, the load limit is about 15 kg (33 lbs), as this is the capacity of the drawer slides. Exceeding this weight may cause wear.
Ethan
15 Nov 2022 12:07
barle schrieb:
IKEA usually states a maximum load of around 10-15 kg (22-33 lbs) per drawer.
The guideline of 10-15 kg (22-33 lbs) is indeed often a rule of thumb for drawers of this type. However, it is also important how the load is distributed. A single heavy object at the front of the drawer puts more strain on the slides than several evenly distributed items.
COLEBAR schrieb:
The load capacity is roughly 12-15 kg (26-33 lbs) per drawer.
That’s correct, so a cautious approach is recommended: better to use less weight, handle carefully, and contact support if you notice any issues.
Wesley
15 Nov 2022 13:22
Timichen schrieb:
I’m planning to use the drawers for heavier items, such as file folders or kitchen utensils.
For kitchen utensils, I would recommend organizing the space, since it’s often not just the weight that matters, but also the size and ease of use. Overloading the drawers can damage the hardware, causing squeaking or jamming over time.
By the way, a small tip: occasionally applying oil to the drawer slides helps keep their operation smooth!
sanjon
15 Nov 2022 14:05
What should also be considered with Hemnes: wood is susceptible to moisture. If you have heavy kitchen utensils in the drawers and the humidity is high, the material can warp and its load-bearing capacity will be affected.
Bagupo
16 Nov 2022 09:08
Just as an addition: IKEA does not provide any written information on the maximum load capacity for Hemnes. Based on my experience, 12-15 kg (26-33 lbs) is a good guideline. Avoid pulling the drawers out completely when they are fully loaded to prevent damage.
Ellis
16 Nov 2022 11:45
I use Hemnes drawers in the office for file folders. A load of about 15 kg (33 lbs) per drawer has proven to be effective; you shouldn’t put more in, as this can damage the slides. Regularly tightening the screws helps keep everything stable.
