ᐅ How can I prevent damage to IKEA Hemnes drawers?
Created on: 4 Dec 2016 19:11
Mausi
Mausi
4 Dec 2016 19:11
Hello everyone, I recently purchased the IKEA Hemnes dresser and unfortunately noticed that the drawers are starting to show signs of damage in some areas – especially on the edges, with slight fraying of the wood. With frequent use, the drawer edges seem to wear down gradually, which is frustrating since I want to maintain the appearance. My question is: What is the best way to prevent damage to the IKEA Hemnes drawers, especially in everyday use when the drawers are often pulled out and stressed? Are there any recommended care or reinforcement methods that I can apply myself without altering the furniture? Thanks in advance for your tips!
tinato
4 Dec 2016 19:23
Hey Mausi! Great question, I also really like the Hemnes series! 😊 For the drawers, I definitely recommend regularly treating the edges with wood protection wax or a suitable maintenance oil. This helps keep the wood flexible and minimizes cracks. Also, try not to overload the drawers – the weight is a key factor! If you notice the wood on the drawer fronts rubbing against contact points, you can gently smooth the rough spots with fine sandpaper. Very important: avoid applying too much force when opening or closing, as this shortens the lifespan of the runners! Good luck, you can definitely do it!
jakob70
4 Dec 2016 19:35
In short: reduce the load, oil the edges, and do light sanding on rough spots. That’s all it takes.
Gerard
4 Dec 2016 20:05
Mausi, to prevent damage to Hemnes drawers, I recommend the following points:
- Regular maintenance with a wood care product suitable for painted or untreated wood to prevent moisture loss.
- Check the screws on the drawers to avoid looseness that can cause pressure marks.
- Use felt pads on the bottom of the drawers to reduce friction during full extension.
- Inspect the sliding mechanism for dirt or wear, which can make opening difficult and lead to mechanical damage.
These measures have been tested and significantly reduce the risk of damage.
Islaso
5 Dec 2016 08:17
I completely understand your concern, Mausi. It’s really frustrating when beautiful furniture shows wear quickly. That bothered me too, so I regularly use a mild furniture oil for maintenance, and when I notice the drawers are sticking, I take the time to carefully clean the tracks. That gives me a good feeling because I see I’m doing something practical for my furniture. And by the way: You’re not alone with this issue; several others have mentioned similar cases here in the forum.
kulau
5 Dec 2016 09:46
Hello Mausi,
I would like to respond to your question in more detail since I personally use several Hemnes furniture pieces and consider drawer maintenance essential.
First, regarding the material: The Hemnes series mainly uses solid pine wood, which is sturdy but, due to its softness, prone to wear marks and dents. Damage often occurs from pressure and friction on the edges.
Recommended preventive measures:
- Cleaning: Regularly wipe with a damp cloth, but avoid harsh cleaning agents to prevent drying out the wood surface.
- Protective layer: After drying, applying a thin layer of furniture wax or hard oil for sealing is advisable. This improves resistance to abrasion.
- Check mechanics: The rollers or drawer runners should be free of dust. Hemnes drawers typically have wood-on-wood slides; smoothing with a dry, fine sanding sponge works well here.
- Reinforce edges: If possible, attach thin protective strips (for example, made of felt or soft plastic profile) inside the edges to reduce direct wood contact during opening and closing.
To conclude, I would like to know how you typically use your drawers (types of items stored, frequency of use) so I can offer more targeted advice. Some usage patterns cause more wear than others.
I look forward to your feedback!
