ᐅ How can I prevent Ikea Metod drawers from falling out?
Created on: 28 Oct 2024 09:13
Mupebo
Mupebo
28 Oct 2024 09:13
I recently installed some Ikea Metod drawers, but despite correct assembly, a few of these drawers keep falling out when I pull them open. My question is: How can I reliably prevent Ikea Metod drawers from coming out of the cabinet? Are there any proven techniques, installation adjustments, or additional parts that can help with this? I am using the Metod soft-close drawer slides, but that doesn’t seem to be enough. I am also curious whether the problem might be caused by incorrect installation of the slides or if there are any special considerations to ensure proper function. Thanks in advance to everyone who shares their experience here!
lisku
28 Oct 2024 09:45
The problem often lies in the adjustment of the rails. With Metod, you need to install the drawer so that the catches at the end engage properly. Otherwise, it will fall out. Simply check if the clips are correctly secured.
likuken
28 Oct 2024 10:02
Let's be honest, if you don't carefully read assembly instructions, you can't be surprised by problems. Ikea designs a function that holds reliably as long as the system is used correctly. Maybe some are meant more for quick assembly than for long-term use.
RENMA
28 Oct 2024 11:15
For safety, here are a few facts: Ikea Metod drawers have so-called extension or locking mechanisms that prevent the drawer from being completely pulled out. If the drawer still falls out, it is usually due to:
- Incorrect assembly or adjustment of the slides
- Damaged or missing locking clips
- Guide elements not fully engaged
First, check the positioning and function of the extension stop. Adjust or replace it if necessary.
DUVIN
28 Oct 2024 12:03
Check the stoppers on the rails. If they are missing or broken, the drawers can fall out. Replacement parts are available at Ikea or in hardware stores.
dijan
28 Oct 2024 12:47
I had the same issue once, and for me it was simply because the rails were not installed completely straight – the drawer would tilt and come out when opened. So my advice is to definitely use a spirit level and tighten all screws securely. Then everything works smoothly on its own!
