ᐅ How durable are IKEA Hemnes furniture pieces with everyday use?
Created on: 7 Oct 2023 08:37
Sinaless47
I am planning to purchase some furniture from the IKEA Hemnes series for my home, especially bedroom furniture and a few small sideboards. I am very interested in how well these Hemnes pieces actually hold up with daily use. In particular, I want to know about aspects such as material quality, stability after prolonged use, effects of frequent opening and closing of drawers, as well as overall durability and ease of maintenance.
Are there any experiences from people who use this furniture daily? How does the Hemnes series compare to other IKEA lines or furniture in a similar price range in general? I am not expecting high-performance cabinet furniture, but it would be important to know if they are suitable for regular use without showing visible signs of wear or loss of functionality after a short time.
I look forward to your assessments and experiences!
faso31
7 Oct 2023 15:48
I think it is important to critically examine why some users report problems. One should not simply assume that Hemnes furniture will always perform equally well under daily use, as much depends on individual handling.
Ethan schrieb:
The drawers and doors hold up well even with frequent opening, as long as they are properly assembled.
What exactly does "properly assembled" mean? Poor or careless assembly could cause screws to loosen faster or wood to split. Often, there is a lack of guidance on the correct procedures, which laypersons may not always follow.
Furthermore: Pine wood is relatively soft, that is a fact. Relevant questions include:
- How do the furniture pieces handle point loads? (e.g., sitting on a dresser occasionally)
- How visible and repairable are scratches?
An uncomfortable aspect: Some Hemnes users report that the painted surface is relatively prone to dents. Are there long-term studies to support this? Such claims should be backed here with concrete user experience.
Jesus9
7 Oct 2023 16:10
faso31 schrieb:
Pine wood is relatively soft, that’s a fact.
That’s true, and especially for someone with children or pets, it’s definitely an important consideration. Even though I know Sinaless47 doesn’t have children, I appreciate you bringing up the issue of possible scratches.
I’ve owned Hemnes dressers myself and can say that despite minor scratches, the furniture still retained its charm and I never had any stability issues. You just have to accept that wood is a natural material that can show signs of wear without necessarily affecting its function.
Maybe you, Sinaless47, could also think about how to protect the furniture if pets get a closer look. Overall, I think Hemnes offers a solid foundation for the price, which with some care and caution can work well.
Tofra45
8 Oct 2023 08:07
When it comes to daily use: Hemnes is sturdy and handles normal wear well. You should take care of the surfaces.
For pets and scratches, a protective film or a clear varnish for touch-ups can help. Tighten screws if needed, and avoid placing too much weight on it.
It suits a typical household with regular maintenance.
Ethan
8 Oct 2023 09:22
This is a very important question that I’m happy to explain in more detail:
"Properly assembled" means using the supplied screws and fittings exactly according to the instructions, not substituting any parts, and tightening connections neither too much nor too little – both can cause damage. Pay special attention to making sure the angles are square and everything is flush to minimize tension and shear forces.
It is also recommended to use tools like cordless screwdrivers with torque control to avoid over-tightening. If you plan to disassemble and reassemble the furniture frequently, avoid using the same screw holes repeatedly, as this can cause the wood to splinter. In such cases, adding wood dowel glue is advisable.
Following the manual’s recommendation to retighten screws every 6 to 12 months is also a good idea, especially for heavily used drawers and doors.
If you move often or frequently take the furniture apart and put it back together, Hemnes may not be the best choice, as the wood can suffer from this.
kulau
8 Oct 2023 10:35
Ethan schrieb:
“Correct installation” means using the supplied screws and fittings exactly as instructed
Exactly, and I would add that with Hemnes, paying special attention to aligning the drawer slides is important. If these are installed crookedly, the load won’t be distributed evenly, which can lead to premature wear.
It is also advisable to handle the top wood layer carefully – avoid harsh cleaning agents or excessive water. This affects the protective finish on the surfaces.
Sinaless47, if you like, I can recommend some care products specifically designed for painted pine surfaces. I can also offer tips on dealing with minor damage, should it occur.
How careful are you with furniture? Are you usually a cautious user, or do you expect some heavier wear and tear in everyday use?
