I am currently looking into how IKEA Hemnes furniture can be recycled effectively. The Hemnes series is mostly made of solid pine wood, which seems to be generally recyclable, but I have not found clear information on how to best handle the individual components—such as wooden frames, fittings, and possibly glass or metal parts—in order to reuse them sustainably or dispose of them properly.
Furthermore, I am interested in whether there are proven methods to dismantle these furniture pieces into their materials so they can be used as raw material sources without generating much waste.
Who can share experience or expert knowledge on how to properly dismantle and recycle Hemnes furniture? Are there practical options for private households, or do you need to rely on professional recycling centers?
Thank you for your suggestions!
I would like to go into more detail about the materials and recycling options for the IKEA Hemnes furniture.
The HEMNES series is primarily made of solid pine wood, coated with a lacquer. While this lacquer adds both aesthetic appeal and protection to the furniture, it significantly complicates recycling because the lacquer must first be removed mechanically or chemically to allow pure wood recycling.
Step-by-step, I recommend:
- Completely disassembling the furniture, carefully loosening strong joints such as dowels to avoid damaging the wood.
- Collecting metal fittings (screws, hinges, handles) and either taking them to a scrap metal dealer or adding them to metal recycling.
- Carefully removing any glass panels and sending them for glass recycling.
- Removing the lacquer by suitable sanding, taking care to use dust protection, or by using a chemical stripper. The chemical method requires appropriate safety measures and environmental precautions.
- After that, the wood can either be used as firewood—provided all lacquer residues are fully removed—or processed in material recycling facilities.
Without these preparatory steps, the wood usually ends up being incinerated or landfilled, which is less environmentally friendly.
What has been your experience with lacquer removal? Does anyone use environmentally friendly methods?
kibutar schrieb:
What has been your experience with paint removal? Does anyone use environmentally friendly methods?I personally recommend mechanical sanding as the most environmentally friendly method, provided it is done in a well-ventilated area with a dust extractor. Chemical paint strippers can be more effective but carry risks for both the environment and health and should only be used with protective equipment and in small quantities.
A small tip: electric sanders with vacuum attachments significantly reduce fine dust.
While manual sanding is labor-intensive, it is the best method to remove paint residues and prepare the wood for upcycling or recycling.
LOGEMIN schrieb:
I personally recommend mechanical sanding as the most environmentally friendly method, as long as it is done in a well-ventilated area with a dust extractor.I completely agree. There are also ways to control the dust on site, such as using damp cloths or targeted vacuuming. If you don’t want to fully refurbish the piece of furniture, you can use wood repair kits to carefully fix damaged or painted spots before repurposing it, for example, as a shelf or bench.
kibutar schrieb:
Without these preparatory steps, the wood often ends up in incineration plants or landfills, which is less favorable from an ecological perspective.Unfortunately, this is a common practice at many recycling centers—material recycling is often prevented due to cost reasons. That’s why the focus is on reusing intact parts through donations or sales.
Thank you for the diverse responses! To summarize, the following points seem important:
- Separating furniture components made of fittings, glass, and metal elements cleanly
- Mechanically removing paint from wood if material recycling is intended
- Passing on intact furniture or parts (donating, selling) for reuse
- Disposing of damaged wooden parts either as firewood (if the paint is removed) or through wood recycling
I wonder how common it is for IKEA or other furniture manufacturers to design furniture from the start for easy recycling. Does anyone have more detailed information on this? Because when you see how many screws, cam locks, or metal fittings are used, it could significantly limit recyclability.
What are your thoughts?
The question regarding IKEA’s design-for-recycling philosophy is very relevant.
From my research, it can be said that in recent years IKEA has increasingly focused on sustainable materials and recycling-friendly constructions.
However, the HEMNES series, due to its relatively traditional structure—solid pine and multi-component fasteners—is not the best example of modular design for easy disassembly.
Many of the current models are optimized for stability and cost, which means frequent use of screws with fasteners that are difficult to separate.
As a result, these pieces of furniture are mostly recycled while still intact (resale, second-hand) or mechanically shredded and thermally processed at the end of their lifecycle.
Complete material recycling is currently challenging for HEMNES due to the composite materials (wood plus lacquered surfaces plus metal).
It remains to be seen how IKEA will proceed in the future, especially as they develop more and more sustainable product lines.
sarla schrieb:
Many of the current models are optimized for stability and cost, which means frequent use of screws and fasteners that are difficult to dismantle.Exactly, I’ve noticed that too, and that’s why I think it’s important to give consumers the option to creatively repurpose furniture!
Instead of taking them apart completely, for example by modifying shelves or turning old dressers into stylish coat racks, you can greatly extend their lifespan and reduce a lot of waste!
To me, this is also a form of recycling—specifically upcycling!
I’d be interested to hear if anyone here has worked on projects like this.
