ᐅ How do I fix squeaking Ikea HEMNES beds?
Created on: 24 Jul 2024 18:07
Lokla66
Lokla66
24 Jul 2024 18:07
Hello everyone, I have a somewhat specific request and hope you can help me with your experience. My Ikea Hemnes bed squeaks when moving, especially when I turn over or get up. It is the typical wooden frame bed with a slatted base, purchased about three years ago.
The noise seems to come from the wooden joints, and obviously, there is some play in the connections. I have already tried tightening all the screws, but that has not permanently stopped the squeaking so far.
So my question is: How can a squeaking Ikea HEMNES bed be properly repaired? Which exact areas should I check, and what materials or tools are recommended to eliminate the noise?
I would appreciate detailed tips, possibly including information on whether the source of the noise is common in certain parts and if there are any special tricks that are not immediately obvious. Thanks in advance for your support!
GALEO4
24 Jul 2024 18:42
Lokla66 schrieb:
I have already tried tightening all the screws, but that hasn’t permanently stopped the squeaking so far.
It’s interesting that you’ve already checked the screws, because honestly, a lot of effort is often spent tightening screws when the problem isn’t actually caused by them.
In my opinion, with beds like the HEMNES, the squeaking usually doesn’t come from the joints themselves, but from the wooden slats of the bed base rubbing against the frame or from friction between individual wooden parts. The only effective solution is targeted damping, such as inserting felt or rubber strips at the contact points.
Simply tightening the screws usually doesn’t eliminate the noise because wood moves and warps slightly. There is always a small amount of micro-movement somewhere that causes the sound.
lyndon
24 Jul 2024 19:03
I partly agree but would like to add the following: Tightening the screws is indeed important, but it is often done inadequately if you don’t use the right tools and follow the correct sequence.
Here is a proven method:
- Loosen all screws
- Then systematically tighten all screws carefully with the appropriate screwdriver (usually a Phillips head)
If the squeaking continues, I recommend treating the contact surfaces of the wooden parts lightly with wax. Furniture wax or even a bit of candle wax can reduce friction without damaging the wood.
It is also worth checking the slatted frame itself: sometimes the slats are no longer tightly seated in their fittings. You can also use felt pads there to prevent noises.
Maria35
24 Jul 2024 19:37
Based on my experience with HEMNES beds, the following can be noted:
- The squeaking is usually caused by friction at the corner joints of the bed frame.
- IKEA uses simple wooden dowels and metal brackets for HEMNES, which can loosen over time.
- Tightening the screws is essential, but only as long as the dowels are not worn out.
I recommend the following method:
- First, loosen all screws and brackets.
- Then check the wooden dowels for a secure fit; if they are loose, they should be replaced or stabilized with wood glue.
- Afterwards, reassemble everything with new screws, possibly adding cushioning material between the joint surfaces (such as foam or felt strips) to reduce friction noise.
Applying a dry lubricant like talcum powder to the contact points is often effective because it does not cause the wood to swell. Oil or grease should not be used, as they cause the wood to swell and may cause long-term damage.
Kinbu
24 Jul 2024 20:11
I can relate well to the previous comments and would like to revisit the basics, in case this is helpful for others as well:
A HEMNES bed is made of solid wood, which constantly reacts to changes in temperature and humidity by warping. This causes slight movements that lead to friction noises between the individual parts.
For a practical approach, I recommend:
- Completely disassemble the bed
- Lightly roughen the wood joints with sandpaper to create fresh surfaces for the glue to bond
- Carefully apply wood glue to all connection points and then reassemble the bed
It is important that the glue fully dries before using the bed again. This can permanently eliminate many squeaking noises.
If this is not possible, felt strips on the contact surfaces usually help by preventing direct friction between the wooden parts.
Filippo
24 Jul 2024 20:56
I approach this very methodically and would like to suggest my repair process, which has proven effective with HEMNES beds:
1. Diagnosis: Identify exactly where the squeaking is coming from – often it’s the corner joints or the area where the slatted frame rests.
2. Disassembly: Take the bed apart as much as necessary to access all the connections properly.
3. Cleaning: Remove dirt and old residues from the contact surfaces.
4. Check fasteners: Replace screws if they are worn or damaged. Check that wooden dowels are firmly seated.
5. Treat friction surfaces:
- Smooth out small rough spots in the wood with fine sandpaper
- Apply a protective layer of furniture wax or a dry lubricant
- Insert felt or rubber strips as buffers between touching wooden parts
6. Reassemble with the correct torque on the screws – not too tight to avoid splitting the wood.
7. Check the slatted frame: Replace sagging or loose slats and add padding if needed.
One question for you: Have you thoroughly checked the slatted frame element as well, or are the noises definitely coming from the bed frame?
