ᐅ How do I fix squeaking Ikea HEMNES beds?
Created on: 24 Jul 2024 18:07
Lokla66
Hello everyone, I have a somewhat specific request and hope you can help me with your experience. My Ikea Hemnes bed squeaks when moving, especially when I turn over or get up. It is the typical wooden frame bed with a slatted base, purchased about three years ago.
The noise seems to come from the wooden joints, and obviously, there is some play in the connections. I have already tried tightening all the screws, but that has not permanently stopped the squeaking so far.
So my question is: How can a squeaking Ikea HEMNES bed be properly repaired? Which exact areas should I check, and what materials or tools are recommended to eliminate the noise?
I would appreciate detailed tips, possibly including information on whether the source of the noise is common in certain parts and if there are any special tricks that are not immediately obvious. Thanks in advance for your support!
Lokla66
25 Jul 2024 08:23
Filippo schrieb:
One question for you: Have you also thoroughly checked the slatted frame component, or is the noise definitely coming from the frame?
Thanks for the detailed process! Yes, I have checked the slatted frame separately. Although it fits a bit loosely in the holders, it doesn’t squeak when I move it on its own. The noise is actually more noticeable at the joints in the wooden frame—especially at the corners.
I will go through your detailed tips step by step. I’m still a bit unsure about the wood glue issue. Wouldn’t that possibly cause tension in the material when reassembling the bed? In other words, isn’t there a risk that parts of the wood could eventually crack due to the glue when the bed is loaded again?
Domau0
25 Jul 2024 09:14
Lokla66 schrieb:
I will go through your detailed tips step by step. Especially the topic of wood glue I cannot fully assess yet.
Your concerns are understandable. When applied correctly, wood glue actually creates a strong bond that enhances the stability of the bed.
Important points:
- Apply a thin, even layer only to the joining surfaces
- After applying, press and clamp the parts tightly together until the glue is completely dry
The glue does not cause additional stress; on the contrary, it makes the individual components act as one solid piece, reducing movement and therefore noise.
I recommend slightly retightening the screws after gluing as a precaution, but be careful not to overtighten. A good workshop clamp or tension strap helps to hold everything firmly in place.
If you like, I can also explain which specific types of glue work best for Hemnes beds.
Josefane
25 Jul 2024 11:03
It is interesting how many focus solely on the adhesive issue. However, may I critically point out that not every layer adhesive provides a permanent solution?
Domau0 schrieb:
Adhesive does not create additional tension; on the contrary, it causes the individual components to act as one piece, which significantly reduces play and thus generates less noise.
That is true, but it largely depends on how the adhesive interacts with the wood, especially with solid wood and changing humidity. Some types of adhesive are not flexible enough and can cause micro-cracks when the wood moves, which in the long run causes more damage than benefit.
Therefore, it is important not to rely on just any wood adhesive, but on one specifically recommended for movable wood parts. Additionally, alternatives such as upcycling and reinforcing connections with metal brackets should also be considered — which might even be more efficient and sustainable.
GALEO4
25 Jul 2024 12:09
Josefane schrieb:
Therefore, it is important not to rely on just any wood glue, but to use one specifically recommended for movable wooden parts.
This is exactly what I often mean – choosing the right method and materials is crucial.
By the way, I think the whole ‘squeaking’ issue might be due to a misunderstanding during product development. HEMNES is very popular, but traditional wooden bed construction without modern damping techniques and high-quality connectors naturally leads to such noises.
Maybe we should suggest IKEA revise the design and ensure that all contact points come factory-fitted with rubber or felt pads.
Until then, the most practical solution remains using felt strips or special lubricants for sustainable results.
Kinbu
25 Jul 2024 14:37
A brief practical tip from my experience: When applying felt strips, do not cut them too large; they should be precisely fitted to the exact contact surfaces, otherwise they might slip or even cause additional noise.
I also recommend gently sanding all surfaces that have been newly planed or polished before assembly, using very fine sandpaper (grit 220 or higher). This helps the glue or wax adhere better and prevents typical wood friction noises caused by rough surfaces.
This method effectively reduces squeaking without having to completely disassemble the bed.
