ᐅ How can Ikea Hemnes furniture be customized with different colors?
Created on: 20 Sep 2019 08:34
Lennymau54
I am planning to customize the color of some furniture pieces from the Ikea Hemnes series, as I find the standard options a bit too plain and would like to add a personal touch. I am particularly interested in different coloring methods – from traditional paint finishes and stains to more creative techniques like decoupage or applying adhesive films. I want to know which approaches work best for Hemnes furniture without compromising functionality or durability.
Additionally, it would be helpful if anyone has experience with surface preparation, especially considering the continuous MDF substrate of these pieces. Which materials are suitable for which applications, which types of paint are compatible, and are there any special considerations for shelves or dressers?
In short: How can I customize Ikea Hemnes furniture with paint or finish to achieve a durable result that looks good?
Looking forward to your tips and experiences!
Lennymau54
20 Sep 2019 12:27
Thanks for the contributions so far!
Tause schrieb:
I would first like to understand why specifically Hemnes? Many IKEA furniture pieces have different surfaces that are easier or harder to work with. Hemnes is usually solid wood or at least veneered, which certainly has its advantages.
It’s precisely the solid wood texture that appeals to me – I hope the surface will accept the paint well. I’m excluding the other series with particleboard or heavily laminated surfaces.
Dwight49 schrieb:
Use of water-based or solvent-based acrylic or chalk paints, depending on the desired finish.
My focus is also on environmentally friendly products, which favors water-based paints. I’m considering that as well.
What do you think about stains or wood finishes to keep the grain more visible instead of fully covering it? Has anyone had experience with Hemnes in this regard?
Tause
20 Sep 2019 13:55
Glazes or stains are generally a good option to enhance the wood grain effect. However, Hemnes furniture is sometimes already lacquered, which significantly hinders the penetration of stain. You either need to completely remove the lacquer layer, which is not always possible without damage on the thin panels, or use very aggressive agents that could potentially harm the wood structure.
An alternative is to use water-based stains or oils that penetrate through sanded surfaces without completely removing the lacquer. Whether this works on Hemnes depends greatly on the condition of the furniture.
In general, I would advise against a full repainting if the natural look is important, as Hemnes is often reinforced with MDF components that do not absorb stain well.
klo40
20 Sep 2019 14:22
About staining: Hemnes consists of a mix of solid wood and MDF, as mentioned before. MDF does not absorb stain because it is a compressed wood fiber material. You can of course stain the visible surfaces made of solid wood, but the other areas will not absorb it, which will result in uneven visual effects.
If preserving the wood grain is the goal, I recommend a transparent, water-based wood glaze specifically made for painted surfaces, applied after light sanding.
Important: Always test all products in an inconspicuous area first to ensure compatibility between the material and the product.
plopra
20 Sep 2019 16:45
Wood stains can work if you thoroughly sand the paint beforehand. Full staining is rather difficult with Hemnes.
My tip: For effects like shabby chic or vintage, simply use chalk paint and then gently sand it; this creates a very natural look.
Z
zartra
20 Sep 2019 17:12
Anyone wanting to change the color of Hemnes should be prepared for multiple layers: sanding, priming, and painting. Only this way will it last.
To my knowledge, using a film or veneer is not ideal because the surface is rough, which can cause bubbles or poor adhesion during application.
Genuan
21 Sep 2019 08:55
I recommend painting with a spray gun if you want a perfect finish – this way you can achieve a very even surface on the Hemnes furniture.
However, some experience with painting is necessary; otherwise, the surface can easily become uneven.
