ᐅ How can IKEA Hemnes furniture be sustainably repaired?
Created on: 23 Dec 2023 09:18
LILUJON
LILUJON
23 Dec 2023 09:18
Hello everyone, I recently bought an IKEA Hemnes piece of furniture and want to repair it as sustainably as possible if it gets minor damage or wears out. I am especially interested in how to handle common issues like scratches, loose joints, or broken wooden parts without having to order replacement parts or replace the entire piece.
Are there proven methods, tools, or materials that work particularly well for these repairs?
Also, what about surface treatment – is it possible to sand the Hemnes wood yourself and then refinish it with paint or oil?
In short: How can IKEA Hemnes furniture be sustainably and long-term maintained or repaired by yourself to avoid premature disposal? Thanks for all tips and ideas!
te-min
23 Dec 2023 09:44
For most Hemnes furniture, I recommend checking all screws and connections first and tightening them if necessary. For scratches, you can use wood filler or wax sticks; they are easy to apply.
Sanding the surfaces is possible, but be careful not to damage the wood too much.
Matthewt48
23 Dec 2023 10:03
Hello LILUJON, your concern is very important since furniture repair makes a significant contribution to sustainability. Hemnes furniture is usually made of solid wood with a certain surface treatment, so you can definitely sand it and then rework it with wood oil or clear varnish.
I recommend that for wobbly joints, you first thoroughly clean the connection points, remove any old glue residues, and, if necessary, replace the screws with suitable new ones.
For broken wooden parts, epoxy wood glue can help, but optimal repair involves fully stabilizing the area with appropriate wooden dowels. If you get stuck, IKEA also provides replacement parts – but this is only necessary for major damage.
Good preparation before repainting is important: start by sanding with fine grit, clean off the dust thoroughly, and then apply several thin coats. This way the furniture will stay attractive longer and the surface will be more durable.
nolan
23 Dec 2023 10:27
Simply fill scratches with a wax stick matching the wood color. For loose joints, check all screws and tighten them as needed. This significantly extends the lifespan.
LOGEMIN
23 Dec 2023 11:15
I would like to share a brief guide on how to repair Hemnes furniture more sustainably:
1. Assess the condition:
- Check all screws and joints.
- Look for any damage on the wooden parts.
2. Screws and fittings:
- Tighten all screws; sometimes applying a bit of wood glue helps if they have become loose.
- Replace damaged screws with original or equivalent spare parts.
3. Scratches and surfaces:
- Small scratches can be easily concealed with wood filler or colored wax sticks.
- For more severe damage: gently sand the area using sandpaper with a grit of 240 to 320.
- Then apply a suitable wood oil or clear stain. Make sure the products are environmentally friendly.
4. Repairing breaks:
- For broken parts, epoxy wood glue is recommended because it is strong and waterproof.
- Support larger breaks from the inside with wooden battens or thin clamps while the glue dries.
5. Regular maintenance:
- Cleaning with mild detergents and occasional re-oiling extends the lifespan.
Common mistakes include sanding too roughly, which removes wood layers, and applying lacquer too thickly, which can cause cracking.
In summary: With some patience, good materials, and regular inspection, you can keep your Hemnes furniture in good condition sustainably.
barle
23 Dec 2023 12:02
Wood glue and a few screws are often enough for a solid repair. For the surface, fine sandpaper and a wood oil are helpful. Nothing more is needed.
