ᐅ What tips are helpful when working with IKEA Hemnes furniture?
Created on: 16 Aug 2017 08:13
Lopeix
Lopeix
16 Aug 2017 08:13
Hello everyone, I recently acquired several IKEA Hemnes furniture pieces, including dressers and nightstands. Since I really appreciate the wood finish and classic style, I want to take good care of them and make the most of their durability. I am especially interested in practical advice that makes handling Hemnes furniture easier, such as assembly tips, maintenance of solid pine wood, protection against scratches, or common mistakes to avoid. Are there any experiences or recommendations that can help keep the furniture in good condition for many years and possibly perform minor repairs on your own? I look forward to specific tips and answers!
Kinbu
16 Aug 2017 09:02
Hello Lopeix, unfortunately, problems often occur during the assembly of Hemnes furniture because the instructions are not followed closely or the correct screws are mixed up. I would recommend sorting all parts and fittings first and reading the instructions step by step without skipping any parts. Small mistakes during assembly can affect the stability over time.
For maintenance: Solid wood like that used in Hemnes furniture is sensitive to direct sunlight and moisture. It’s best to wipe it regularly with a damp cloth, but not soaking wet, and occasionally use a suitable wood wax or oil that protects and refreshes the surface. Scratches can be repaired with polish or wood touch-up markers in the matching color. If you like, I’m happy to help with more detailed instructions.
nikian
16 Aug 2017 11:47
In addition to what Kinbu has already mentioned, the location of the Hemnes furniture is crucial. Although Hemnes is sturdy, it is highly sensitive to fluctuations in humidity. The wood may warp or develop cracks if the air humidity remains consistently too high or too low. An indoor climate with humidity levels between 40 and 60% is ideal. Also, avoid using harsh cleaning agents, as they can damage the white or lacquered surface. If there are minor discolorations, these can sometimes be improved by gentle sanding and re-oiling, but this requires some practice.
LANICOLE
16 Aug 2017 14:16
Hello Lopeix, I’ll give you a quick overview of how I handle Hemnes furniture to ensure everything lasts in the long run:
- First of all: never fully tighten the screws before all parts are assembled. Otherwise, the whole thing often doesn’t fit properly.
- Assemble on a soft surface (e.g., carpet) to protect the wood from scratches.
- Pay close attention to the labels on the fittings, as Hemnes uses several similar screws.
- For maintenance, I use a slightly damp, soft cloth to remove dust, followed by a special wood care spray that lightly protects the wood without leaving a greasy film.
- You can repair scratches with special wax sticks available at woodworking stores. If the appearance is heavily affected, light sanding with fine sandpaper (grit 320 or higher) and then applying an oil-based treatment helps.
- For repairs, I recommend using a strong wood glue if parts come loose.
- Important: regularly check the furniture and tighten screws as needed.
If you have any questions about assembly, feel free to ask.
Giagau
16 Aug 2017 16:49
I would like to add that with Hemnes furniture, the solid pine material is a relatively soft type of wood, so careful handling is important. Heavy loads near joints should be avoided to prevent screws from loosening or the wood from tearing. It is also important to ensure a flat and stable surface, as uneven floors can create stress that weakens the structure. Another tip is to use wood glue in addition to screws during assembly to further increase stability – this is especially useful for heavily used parts. Additionally, the weight distribution in drawers and shelves should not be too uneven.
Lopeix
17 Aug 2017 07:33
Thank you very much for the detailed answers so far! I have a specific question regarding scratches and minor damages: Which methods and products are specifically recommended for repairing small scratches on the Hemnes surface lacquer and the natural wood? Are there differences between the white lacquer finish and the untreated wood variant that I should keep in mind when caring for them? I want to choose the correct approach to avoid making mistakes.
