ᐅ How can Ikea Hemnes furniture be repaired in a sustainable way?
Created on: 30 Dec 2023 08:13
leon1
leon1
30 Dec 2023 08:13
A few years ago, I bought some furniture from the Ikea Hemnes series, which I really like both in terms of design and quality. Unfortunately, some pieces are now showing typical signs of wear, such as scratches in the finish, small dents in the solid wood, as well as a few loose screws or slightly wobbly joints.
My question to you is: How can Ikea Hemnes furniture be repaired sustainably without having to sand down or repaint the entire surface? I am looking for methods that are as simple and resource-efficient as possible—ideally using materials that are easy to find and that match the typical Hemnes finishes. If anyone has tips on maintenance, repair products, or specific techniques, I would be very grateful!
Dilen
30 Dec 2023 09:47
Sustainable repair of Ikea Hemnes furniture is definitely achievable, but a few details are important: Hemnes furniture is largely made of solid wood, usually pine, which has an open grain and is often coated with a clear finish. If you have scratches or dents, I recommend starting with a suitable wood repair wax or wood filler. These can be color-matched and effectively fill small imperfections with minimal effort.
Here is the recommended procedure:
- First, lightly clean and degrease the damaged area
- Apply the wax with a spatula and immediately remove any excess material
- After it’s fully dry, you can gently polish the area with very fine sandpaper (around grit 320–400) if needed
- If the surface texture is disturbed, a thin layer of paint or a matching clear coat can help visually blend the repair with the rest of the piece
Make sure to work discreetly to avoid visible differences. For loose screws, it’s usually enough to tighten them or replace them with new screws of the same type. Have you already checked whether the original screws are still in good condition or possibly rusty or bent?
GALENKU
30 Dec 2023 10:05
Touch up scratches with furniture wax or colored markers. Check screws and replace if necessary. A full repaint is not required.
benon
30 Dec 2023 11:22
I would like to add that with Hemnes furniture, which is often oiled or waxed, you should be especially careful when doing extensive sanding. Removing or repainting the surface can cause color variations. My recommendation is to use special repair kits for wooden furniture, which are available at hardware stores. These often include wax sticks, polishing pastes, and even small bottles of oil or varnish that are color-matched.
Additionally, it helps to regularly treat the furniture with a suitable wood care product alongside any repairs. This can help protect the surface texture and minimize minor damage early on. Do you have any experience with such kits, or do you use any particular care products?
Dilen
30 Dec 2023 11:45
benon schrieb:
My recommendation: Use specialized repair kits for wooden furniture, which are available at hardware stores.
Absolutely, such kits are a good solution. However, I would also pay attention to compatibility: some wax sticks are too soft for harder wood and do not adhere well, especially on solid surfaces. For Hemnes, it is ideal to choose a wax specifically designed for pine and similar light-colored woods.
leon1
30 Dec 2023 12:17
Thank you in advance for these detailed answers. I would like to clarify something: The furniture is actually painted, not oiled – as far as I can tell. So far, I have generally avoided sanding, out of concern that it might damage the paint even more.
One of the dressers has a drawer that is somewhat difficult to open and close, probably due to dirty runners. Are there sustainable ways to make it slide smoothly again without using chemical sprays that might be harmful to the climate?
Additionally, I wonder if the often annoying small white spots (paint wear) on the edges can simply be touched up with colored pencils, or if that would be too noticeable visually and make the repair obvious right away?
