ᐅ How can Ikea HEMNES furniture be protected in conditions of high humidity?
Created on: 14 Oct 2019 08:37
BUJU67
Some time ago, I purchased several Ikea Hemnes furniture pieces. Since I am placing them in a room with relatively high humidity—around 65-75%—I am concerned about the durability and protection of the furniture against potential swelling, warping, or mold growth.
My question is: What methods or measures would you recommend to effectively protect Ikea Hemnes furniture, especially in environments with high humidity?
I am interested in approaches for prevention, proper care, and possible sealing techniques that do not affect the natural look of the wood but provide better resistance to moisture.
Are there any experiences with specific varnishes, oils, or other protective products? And what about climate control at the installation site in general?
Looking forward to your tips and the discussion!
O
onron
14 Oct 2019 12:25
I would like to add some information about moisture protection for Hemnes furniture.
Since the furniture is made of solid pine, the natural swelling and shrinking of the wood cannot be avoided. The goal should therefore be to minimize these fluctuations.
Using treatment products that maintain flexibility, such as special wood oils and waxes, helps reduce cracks and deformations.
Additionally, it is important to ensure that moisture does not accumulate underneath the furniture. Because the furniture is often placed on wooden or vinyl floors, it can be useful to apply a thin insulation layer to prevent trapped moisture.
Those living in very humid environments should also consider using air conditioning or at least an electric dehumidifier.
lis64
14 Oct 2019 12:56
Protecting HEMNES Furniture in High Humidity:
- Ensure good ventilation
- Oil the furniture (do not use lacquer)
- Keep a gap between the furniture and the wall
This is usually sufficient.
nedagla
14 Oct 2019 13:23
One more tip from me: When applying wood oil, take your time! Several thin layers are much better than one thick layer. This way, the wood can absorb the oil optimally and stays flexible.
Also: For furniture that is constantly exposed to moisture, it’s worth investing in a good natural wax as a finishing coat.
I did this with my HEMNES sideboards – it looks great and provides excellent protection!
BUJU67
15 Oct 2019 07:49
Thanks for the great tips so far!
I have one more question: Could you possibly recommend specific products or brands of wood oil or wax that work particularly well for pine wood in high humidity?
Is it also possible to use furniture oils that are typically used for outdoor wood? And what are your thoughts on lightly sanding again with fine sandpaper before applying a new coat of oil?
I’m really looking forward to more practical experiences!
Brian
15 Oct 2019 08:27
Hello BUJU67,
to address your questions:
Garden wood oils are often designed for highly weather-resistant wood types and sometimes contain ingredients that are not ideal for indoor furniture, as they may have curing properties or odors. For HEMNES furniture, I would therefore recommend using specific indoor wood oils, such as linseed oil with additives that are suitable for furniture.
Regarding sanding: Yes, a fine sandpaper (grit 320 or higher) can help to slightly roughen the surface between coats, so the next layer adheres better. However, you should sand very gently to avoid damaging the wood.
It is also advisable to dust off the furniture with a fine cloth after sanding before applying the new oil coat.
You don’t have to repeat the whole process too often – usually inspecting once a year and re-oiling as needed is sufficient.
mesila
15 Oct 2019 09:14
BUJU67 schrieb:
Is it possible to use furniture oils that are typically used for garden wood?
Please be cautious here! Oils for garden wood are usually designed for very durable outdoor wood and often contain fungicides or chemical additives that can be harmful to health indoors.
My advice: Use wood oils specifically formulated for furniture that are certified safe for indoor use.
BUJU67 schrieb:
What do you think about lightly sanding again with fine sandpaper before applying a new layer of oil?
That is a very good practice to achieve a smooth surface. But: Use only very fine sandpaper and apply light pressure, otherwise the wood fibers can be damaged. Afterwards, as Brian mentioned, make sure to remove the dust thoroughly.
Proper maintenance is key!
