ᐅ How do I clean IKEA Hemnes furniture to remove stubborn stains?
Created on: 13 Dec 2015 08:17
SehapaHello everyone, I’m currently cleaning my IKEA Hemnes furniture but I’m struggling with some stubborn stains that haven’t come off with a damp cloth or standard cleaning products. Since these pieces are mostly made of lacquered pine wood, I want to avoid damaging the finish. So my question is: What’s the best way to clean IKEA Hemnes furniture when dealing with tough stains without harming the lacquer? Have you tried any home remedies or special cleaning products that you found effective? I look forward to your tips and experiences!
Hey Sehapa, your question comes at a good time – I recently encountered that annoying coffee stain on my Hemnes desk too. My tip: start by using a soft cloth with lukewarm soapy water; that usually works pretty well. For more stubborn stains, try a vinegar-water mixture, but be gentle to avoid damaging the finish. If that doesn’t do the trick, I usually turn to a specialized wood care product from IKEA itself, which is milder than most alternatives. It’s important not to scrub too hard, as that can damage the surface quickly. Good luck and don’t worry – stains can be managed! 😉
minKarson13 Dec 2015 09:12Dilute vinegar essence with water, moisten a cloth, and gently wipe without rubbing. Afterwards, wipe again with clean water and allow to dry thoroughly.
Hello Sehapa, I completely understand your caution, as Hemnes furniture is often coated with a thin lacquer that isn’t very durable. It’s really important to avoid harsh chemical cleaners or abrasive sponges, as they can damage the lacquer. If water and mild soap aren’t enough, try using a microfiber cloth with a furniture polish designed specifically for lacquered wood; this can often remove small stains while protecting the surface. Some users also recommend a paste made from baking soda and water, applied gently to the stain, left for a short time, and then wiped off carefully. If you provide more details about the stains, such as what caused them (e.g., oil, paint, ink), I’d be happy to offer more precise advice.
I really appreciate how carefully you’re approaching your Hemnes furniture. I recently faced a similar issue and felt quite frustrated because nothing seemed to work. Sometimes, situations like these just make me feel powerless. But from experience, I can say that patience is key! For me, a gentle baking soda cleaning paste and letting it sit for a while helped a lot. It’s important not to scrub too hard afterward, or the marks become even more visible. If you ever feel completely stuck, I also find that taking the furniture outside into fresh air and sunlight for a short time can help – sometimes the wood becomes a bit more reactive, making stains easier to remove. Don’t worry, you’ll manage it!
Hello, I would like to add to nikian’s point, as they have already mentioned important basics. Hemnes furniture is made from solid pine wood with a thin layer of varnish, so it is sensitive to harsh cleaning agents. I recommend: - Analyzing the type of stain (e.g., grease, ink, watermarks) - For grease stains: apply a drop of dish soap in water, gently apply - For ink stains: use alcohol on a cotton swab, not over large areas - Always polish with a soft cloth, never scrub - Afterwards, you can care for the varnish layer with furniture wax or wood oil It is important to always test in an inconspicuous spot first. If the stains have penetrated deeply, professional restoration products might be helpful, but I would only recommend this as a last resort.
