ᐅ How can Ikea Hemnes furniture be enhanced with LED lighting?
Created on: 31 May 2022 08:17
NoLaurenceN
NoLaurence31 May 2022 08:17Hello everyone, I am currently looking into how to effectively add LED lighting to IKEA Hemnes furniture to enhance both appearance and functionality. I am especially interested in which types of LED systems work best with these pieces, which are mostly made of solid pine wood, how to integrate the lighting as discreetly as possible, and whether there are specific technical or design challenges to consider when working with Hemnes furniture. I would greatly appreciate any tips on installation, suitable products, and possibly experiences with modifications to the furniture structure.
The idea of enhancing IKEA Hemnes furniture with LED lighting is generally good, but it’s important to be clear about the intended purpose: Is it mainly for ambiance, accent lighting, or direct task lighting? Only with this understanding can the right LED technology be chosen. It is also often overlooked that LEDs can generate heat depending on the installation location, which could affect solid wood. Such factors should not be ignored when selecting LED strips or fixtures. Does NoLaurence already have a specific use case to help focus the discussion?
NoLaurence31 May 2022 09:45faso31 schrieb:
Is there already a specific use case from NoLaurence to clarify the discussion?Thank you for asking! Specifically, I plan to equip the Hemnes dressers in my bedroom with LED under-cabinet lights to create a warm, indirect light that can be turned on in the evening without being too bright. Additionally, I want to install subtle interior lighting in the display cabinet to highlight the decorative items inside. It is important to me that the cables are discreetly routed and that the installation is as reversible as possible, as I do not want to permanently alter the original appearance.
FeAndreas131 May 2022 11:22To optimally complement your Hemnes furniture with LED lighting, it is first advisable to measure the exact dimensions of the installation areas and plan the power supply accordingly. For underneath dressers, flexible LED strips with a warm white color temperature (around 2700–3000 K) are particularly suitable. These can be mounted in a slim profile channel with a diffuser, which prevents harsh shadows and distributes the light evenly. It is also important to ensure that the LED strips are dimmable, so you can adjust the brightness based on the desired atmosphere. For interior lighting of display cabinets, I recommend small, focused LED spots or miniature lights that can be battery-powered or wired with very thin cables, allowing the cables to be hidden in the back or along edges.
When installing, it is crucial to drill holes and screw openings very precisely to avoid damaging the furniture or reducing its load-bearing capacity. Use thin drill bits and insert screws carefully, possibly with small washers for better grip.
Also, it is better to use branded LED strips with high-quality chips (e.g., from Samsung or Cree), as these tend to be more durable and have better color accuracy. In the Raspberry Pi and smart home sectors, there are often compatible controllers that allow you to control the LEDs via smartphone or voice assistants, if you are interested in smart control.
Have you already considered whether the power supply near the furniture will be easily accessible? It is important to clarify how to connect the LEDs before installation.
For the LED lighting of Hemnes furniture, I recommend:
- Using flexible LED strips with warm white light
- Purchasing mounting clips to attach the strips neatly
- Using a dimmable power supply
- Concealing cables behind the furniture
This combination ensures a clean and discreet result.
An important aspect that is often underestimated is the choice of power supply. For Hemnes furniture, power adapters with a small size are ideal because they can be placed under or behind the furniture to avoid tangled cables. Additionally, I recommend LED strips with an IP20 rating, as this level of protection is sufficient for indoor use without the extra cost of waterproof variants. A color temperature between 2700 and 3000 Kelvin (4900 to 5400 Fahrenheit) is also optimal since it makes the natural wood of the furniture appear warmer and more appealing.
From my experience, it is also important to ensure that LED strips have a sufficiently long adhesive layer so they can firmly attach to slightly uneven wood surfaces. Before installation, I suggest cleaning the surface with isopropanol to remove any grease.
