ᐅ How can IKEA HEMNES furniture be repaired quickly and easily?
Created on: 16 Jan 2023 08:34
TUYETTUGood morning everyone, I am addressing my question specifically to those who have experience with repairing IKEA Hemnes furniture: How can Hemnes furniture be repaired quickly and easily if, for example, a drawer sticks, a hinge is loose, or a surface has small scratches? I am looking for practical tips that do not require much special tooling or replacement parts, but can be done in everyday situations. Thank you in advance for your help!
For a quick repair of the HEMNES series, I recommend first systematically identifying the cause: if a drawer sticks, it is often due to dirty or damaged sliding rails. In most cases, cleaning the rails and lightly lubricating them with silicone spray or wax helps.
Loose hinges can be easily tightened with a Phillips screwdriver—make sure to use the correct screw size. Surface scratches can be removed with a furniture touch-up marker or special wax repair kits, which are available in matching wood tones.
This procedure does not require a professional; most tasks can be done with a small tool kit.
Oh dear, the classic HEMNES furniture has always had that charming “vintage look” after a few years – meaning: small dents and scratches included 😂.
For drawer sticking: Simply check the tracks for any foreign objects and maybe apply a little olive oil – it works wonders and you usually have some at home.
And very important: Small surface scratches? Often a walnut can help! Just rub the area with the walnut, wait a moment, then polish. The oils in the nut’s kernel usually conceal the scratches quite well. Quick, inexpensive, and somewhat sustainable! 😉
I will provocatively suggest that many repair attempts on IKEA furniture drag on precisely because people believe they need to be especially meticulous.
In reality, these pieces are designed to be somewhat ‘disposable.’
Those looking for a quick fix should, in my opinion, consider pragmatically replacing parts or using simple improvised solutions—for example, instead of fixing the hinge, just attach a small wooden strip inside to stabilize the seat.
Anything else is a waste of effort.
As an addition: If drawers are sticking, you should not only clean the slides but also properly realign them. With HEMNES, screws may loosen over time, causing the slide to no longer sit flush. In these cases:
- Completely loosen the screws
- Reposition the slides and tighten the screws
- Reinsert the drawer and check for smooth operation
For damaged surfaces, there are special wood repair kits available that include color markers, wax, and filler. These kits are relatively affordable and usually provide a visually pleasing repair that is quicker than repainting.
I would like to highlight one point: It is recommended to regularly retighten screws at all connection points in the HEMNES series – this is often the main reason for wobbly or unstable furniture.
No special tools are needed for this; a standard Phillips screwdriver is usually sufficient.
For drawers: Also check the guide rails for damage and replace any defective rollers if necessary, as this often prevents a lot of trouble.
