ᐅ How can I repair damage to IKEA Hemnes furniture myself?
Created on: 21 Jun 2022 08:17
Faongla
Faongla
21 Jun 2022 08:17
Good morning everyone, I have been using various IKEA Hemnes furniture pieces for several years now, mainly dressers and nightstands. Unfortunately, over time, some typical signs of wear and minor damage have appeared – including scratches on the surface, chipped corners from impacts, and in some places, hinges that have become slightly misaligned or loose. My question is: How can I effectively repair these Hemnes furniture damages myself without having to replace entire parts? Are there proven methods specifically suited for the MDF and solid wood fronts of Hemnes furniture, including advice on suitable wood glue, fillers for painted surfaces, and screws or replacement fittings? I would like to learn from your experiences how to maintain the value of my furniture without complicated restoration or professional help. I appreciate any kind of guidance, preferably with practical tips, tool usage, and possible pitfalls to avoid.
Ramon4
21 Jun 2022 08:48
Hello Faongla, your concern is very understandable and shows that you are really engaged with your Hemnes furniture. Minor damages like scratches and chipped corners can often be repaired with some household remedies and targeted repair kits. Specifically for Hemnes furniture, which combines an MDF body with solid wood fronts, this works as follows:
- For surface scratches, I recommend special wood repair markers that can be color-matched.
- Chipped corners can be carefully glued back with wood glue or white glue if necessary, applying some pressure while drying, provided the broken piece is still available. Otherwise, wood filler helps.
- For screws that no longer hold, you should first try to fix the old dowel with some wood glue or slightly enlarge the drill hole diameter and use a bigger dowel.
It is always important to either repaint the surface or seal it with clear wood protectants afterward to ensure everything is well protected and visually consistent again. Feel free to ask if you need more details on any of these points.
barle
21 Jun 2022 09:13
Scratches can usually be fixed with wax or a repair pen from a hardware store. For chipped corners, simply fill them with wood filler and sand once dry. Loose screws? Use a larger anchor or apply wood glue into the hole and let it dry.
Timofa
21 Jun 2022 09:45
Hey Faongla! Your Hemnes furniture has probably been through a lot – don’t worry, with a bit of skill, those small issues can be fixed quickly.
You can treat scratches, for example, with dark furniture wax or an appropriate wax crayon. Some also swear by a mixture of walnut oil and petroleum jelly – great for refreshing the surface!
Regarding chipped corners: wood glue – preferably cold-pressed white glue – and a bit of patience to hold it in place usually work very well. If a piece is missing, a wax-based filler or fine ceramic repair putty can work wonders.
If hinges are sticking, simply remove them, clean, and re-lubricate. And yes: a bit of sandpaper (grit 240–320) is your best friend. 😉
Good luck, soon they’ll look like they just came out of the showroom!
Tofra45
21 Jun 2022 10:12
Lever broken? Contact spare parts suppliers. Rub scratches with furniture polish. Use wood filler for chipped areas and sand smooth.
daalessio
21 Jun 2022 10:51
Faongla, to answer your question precisely: Hemnes furniture is usually made of MDF with real wood veneers. For repairing damage, a suitable approach is recommended.
1. Surface scratches: Use fine sandpaper (grit 320 or higher) carefully, then treat with color-matched furniture wax or a touch-up pen.
2. Chipped corners: Re-glue wooden parts as much as possible; for missing pieces, shape them using epoxy wood filler.
3. Hinges/mechanics: Obtain original replacement parts from IKEA, and if necessary, repair screw holes with wood filler or wood glue.
Additionally, after repairs, always apply a protective coating of varnish or oil. This helps prevent further damage.
Tools such as fine sandpaper, furniture repair kits, and wood glue form the basis; everything else depends on the type of damage.
