ᐅ How can I repair damage to IKEA Hemnes furniture myself?
Created on: 21 Jun 2022 08:17
Faongla
Good morning everyone, I have been using various IKEA Hemnes furniture pieces for several years now, mainly dressers and nightstands. Unfortunately, over time, some typical signs of wear and minor damage have appeared – including scratches on the surface, chipped corners from impacts, and in some places, hinges that have become slightly misaligned or loose. My question is: How can I effectively repair these Hemnes furniture damages myself without having to replace entire parts? Are there proven methods specifically suited for the MDF and solid wood fronts of Hemnes furniture, including advice on suitable wood glue, fillers for painted surfaces, and screws or replacement fittings? I would like to learn from your experiences how to maintain the value of my furniture without complicated restoration or professional help. I appreciate any kind of guidance, preferably with practical tips, tool usage, and possible pitfalls to avoid.
chen67
21 Jun 2022 11:19
I just came across your question about sandpaper and wax crayon tips – really practical! My Hemnes dresser had a small water stain at the bottom, which I sanded off with fine sandpaper. Then I applied color-matched tinted wood wax over it. It looked much better afterward; I didn’t expect to be able to do something like that myself.
A quick tip for chipped areas: I used a worn, fine brush with wood glue and a bit of sandpaper to even out irregular edges. It’s relatively quick. Just be careful when sanding not to damage the surrounding varnish surface.
todunar
21 Jun 2022 12:03
Great topic, thanks for starting this! =) I can only encourage you: Repairs can actually be really enjoyable when you get into them! 👍 With my Hemnes pieces, I occasionally check the screws, otherwise nothing comes loose. The important thing is to be patient and not panic if something doesn’t fit right away. Small damages often aren’t a big deal – take it easy, and it will work out.
rigau
21 Jun 2022 12:35
Gluing corners: Quickly check if you still have enough material. It is best to use PVA glue. Screws usually hold again when using wood filler as core plugs.
Faongla
22 Jun 2022 07:54
Thanks in advance for your tips; they really help me understand the approach better. Could you be more specific about whether wood filler works well on the white Hemnes surfaces? I have read that there are often problems with painted MDF parts because fillers are not available in matching colors, and repainting is always necessary after sanding.
Are there any recommendations for creating touch-up paint colors that match as closely as possible in such cases, or is it better to rely on special IKEA replacement parts if you want a finish without color differences? Do you always have to completely repaint damaged closed fronts, or are there tricks to make repairs less noticeable? More details on the painting process would be very helpful.
Ramon4
22 Jun 2022 08:37
Good question. Especially with the white Hemnes fronts, repainting is often the crucial point.
Faongla schrieb:
I have read that painted MDF parts often cause problems because fillers are not available in the exact color tone
Exactly, that’s why I like to work in two steps:
- First, fill the damage with white wood filler and once dry, sand it very finely (finest grit!) to make the surface as even as possible.
- Then touch up with a high-quality acrylic paint pen. There are universal shades of white that come close to IKEA white, but this is not an exact color match, just an approximation.
Another option is to request small paint samples from hardware stores to match the color precisely. Completely repainting will give a perfect result but is more time-consuming and requires painting tools and patience.
Using only filler without repainting often leaves a slightly gray spot visible under white paint – which stands out. Replacement parts only make sense if the damage is large or mechanically irreparable.
In short: repainting is the key to a clean result.
barle
22 Jun 2022 09:10
For repainting, I recommend matte acrylic paint that matches the IKEA white. Small bottles are often available at hardware stores. Be sure to use white wood filler and sand it well afterward.
