ᐅ How can I repair damage to IKEA Hemnes furniture myself?
Created on: 21 Jun 2022 08:17
Faongla
Good morning everyone, I have been using various IKEA Hemnes furniture pieces for several years now, mainly dressers and nightstands. Unfortunately, over time, some typical signs of wear and minor damage have appeared – including scratches on the surface, chipped corners from impacts, and in some places, hinges that have become slightly misaligned or loose. My question is: How can I effectively repair these Hemnes furniture damages myself without having to replace entire parts? Are there proven methods specifically suited for the MDF and solid wood fronts of Hemnes furniture, including advice on suitable wood glue, fillers for painted surfaces, and screws or replacement fittings? I would like to learn from your experiences how to maintain the value of my furniture without complicated restoration or professional help. I appreciate any kind of guidance, preferably with practical tips, tool usage, and possible pitfalls to avoid.
chen67
22 Jun 2022 09:45
A tip from me: I always use a foam brush for painting the white areas, as it provides a very smooth finish. For the paint itself, I prefer to dab it on with a small sponge, which makes brush strokes less visible.
Also, let the paint dry thoroughly after two coats to ensure a durable surface. This way, the repaired spot is hardly noticeable afterward. Good luck!
Faongla
23 Jun 2022 07:22
Great, thanks for all the helpful answers and the discussion. I have now decided to fill the damaged areas initially with white wood filler, and then carefully touch them up using a suitable matte acrylic paint pen. I will sand gently with 320-grit sandpaper and then apply several thin layers of paint.
Overall, this should restore the furniture’s durability and a neat appearance, in my opinion. I will report back once I have finished the repairs.
todunar
23 Jun 2022 15:16
Glad to hear you’ve made your decision! When choosing the paint color, be sure to be patient and apply several thin coats instead of one thick layer. This will make the surface more durable and less noticeable. Looking forward to seeing your results, good luck!
