ᐅ How can I properly clean BILLY shelves without damaging the surface?
Created on: 13 Feb 2022 08:17
Nafe2
Nafe2
13 Feb 2022 08:17
I have a question regarding the cleaning of IKEA Billy shelves. These shelves have a coated surface – often melamine-coated or covered with a laminate film. Now, I’m wondering: how can I clean Billy shelves properly without damaging the surface or causing unattractive scratches or peeling?
I am particularly interested in which cleaning agents are recommended, whether to use damp or dry cloths, and if certain cleaning tools should be avoided to protect the material.
Does anyone have experience or tips, maybe even advice on long-term maintenance to keep the shelves looking good? I would appreciate a detailed response, as I want to avoid risking damage to the surface from improper cleaning.
Timmyse36
13 Feb 2022 08:45
Hello Nafe2,
I completely understand that the surface of your BILLY shelves is important to you. I know very well how worrying it can be to damage something. So far, I have always cleaned my shelves with a slightly damp microfiber cloth. I avoid using harsh cleaners and only use mild dish soap diluted in water.
Sometimes it can be tricky to remove stubborn dirt without risking damage to the surface. What has helped me is not scrubbing too hard and wringing the cloth well before use so that it is just damp, not wet. This helps prevent water from seeping into edges or joints and causing the material to swell.
I hope this helps you a bit! 🙂 If you want to hear more about special cleaners or alternative methods, I can try to find out more.
Ankeli
13 Feb 2022 09:02
Hi,
I always use a soft cloth and warm water with a few drops of dish soap to clean the BILLY shelves. Avoid abrasive cleaners or harsh chemicals! After cleaning, wring out the damp cloth well.
This is completely sufficient for normal dust and light dirt.
tolokau
13 Feb 2022 11:23
I would like to provide a brief guide on how to properly clean BILLY shelves without damaging the melamine surface.
1. Preparation: Avoid using aggressive cleaning agents, as they can damage the laminate coating.
2. For daily cleaning: A slightly damp microfiber cloth works best. Moisten the cloth just enough to avoid water seeping into the edges.
3. For heavier dirt: Dissolve a small amount of mild dish soap in lukewarm water, dip the cloth in, wring it out thoroughly, and then wipe the surface.
4. Avoid: Scouring pads, steel wool, or harsh chemicals. Also, avoid scrubbing too hard, as this can cause uneven gloss spots on the laminate finish or create very fine scratches.
5. After cleaning: Wipe again with a dry cloth to remove moisture and refresh the surface.
Summary: A soft, well-wrung microfiber cloth and mild cleaning solution are the best approach.
I hope this guide helps you, Nafe2.
bupar
13 Feb 2022 13:17
@Nafe2
Your concern about damaging the surface is justified. The BILLY shelves are made of melamine-coated particleboard, which is relatively durable but sensitive to solvents and mechanical stress.
I recommend the following approach:
- Clean only with a soft, lint-free cloth, preferably a microfiber cloth
- Avoid any abrasive materials (e.g., scouring pads, brushes with stiff bristles)
- Do not use harsh cleaners (alcohol, acetone-based products, etc.)
- For regular cleaning: use lukewarm water with a mild dishwashing detergent and wring the cloth out thoroughly
- Wipe again with a dry cloth to prevent water spots
These guidelines are based on the material properties, and similar recommendations can be found from IKEA itself.
The coating is prone to scratches, so mechanical stress should be kept to a minimum.
Repar
13 Feb 2022 14:02
I clean my BILLY shelves like this: a slightly damp microfiber cloth with mild dish soap, then wipe dry.
No alcohol, no abrasives, no harsh chemicals.
This is completely sufficient to protect the surface and keep it clean.
